OVTune - 2/20/21!
Discussion in 'Arizona' started by tclavell, Feb 6, 2021.
  1. Feb 12, 2021 at 11:51 AM
    #41
    rocketjones
    rocketjones Member
    21 SR5
    Stock
    In for a tune. PM sent.
    TWTaco and tclavell[OP] like this.
  2. Feb 12, 2021 at 11:52 AM
    #42
    tclavell
    tclavell [OP] Assistant to the Assistant Manager
    Troy
    Phoenix, AZ
    G70
    Great. Thanks, Ian! PM replied to. I'll add you to the confirmed list
    Please see message in this thread about getting your truck information over to @TWTaco
    taco_jak and TWTaco like this.
  3. Feb 13, 2021 at 6:56 PM
    #43
    taco_jak
    taco_jak Well-Known Member
    18 TRD Sport 4x4
    @TWTaco
    Is there a difference in ECT mode after the tune?
    Right now I really never use it, it just holds on to the gears longer and it just makes cruising the highway annoying when it stays in lower gears longer for minor elevation changes.
  4. Feb 13, 2021 at 7:00 PM
    #44
    TWTaco
    TWTaco Well-Known Member
    Dave
    Here is a good description of our Performance tune.
    -Aggressive/predictable throttle response
    -Smooth predictable shifting at slightly higher shift points
    -Very peppy in gears 1-4, holds 5-6 on highway (for good MPGs)
    -More noticeable low end power/torque
    -Cruise Control shifting matches primary shifting for improved function
    -ECT for a little extra throttle and a little higher RPM shifting--good for towing and Extra performance.
    -S mode uses performance shift points and throttle
    taco_jak[QUOTED] likes this.
  5. Feb 13, 2021 at 7:24 PM
    #45
    New4x4
    New4x4 Well-Known Member
    AZ
    2017 Tacoma 4x4 TRD Off Road DCSB
    All-Pro Sliders Dirty Deeds Industries Exhaust
    never tuned a truck before, but what would happen down the road if I add a lift, changed gearing etc... would the tune need to be readjusted? If i don't what would happen to the truck? Lack of knowledge and curiosity. Looking for worst-case and how would I get a new tune to match the change?
  6. Feb 13, 2021 at 7:37 PM
    #46
    taco_jak
    18 TRD Sport 4x4
    I cant speak for the tuners but I can say that the tune needs to be customized for tires/gears because those are the questions they ask. I dont know how it will affect your drive if you roll with a tune and then upgrade tires and/or gears.
  7. Feb 13, 2021 at 7:42 PM
    #47
    TWTaco
    Dave
    A lift wont change anything. Tire size you will be fine on the custom tune. If you change gears then you may need to change tunes. On 4.88's is what I have and I have tested the performance tune with and without gear settings changed and there is a slight change in shift points. But still drives good.Now if you are going 5.29's with 35's i would say re flash to a 5.29 tune. You would need to make arrangements to get the tune file changed.How soon would you be making the changes?
    PapaRee likes this.
  8. Feb 13, 2021 at 7:55 PM
    #48
    New4x4
    AZ
    It will be a while for regear. I want a lift first.
  9. Feb 13, 2021 at 7:57 PM
    #49
    TWTaco
    Dave
    You will be fine. When you do decide to regear then we can maybe make some kind of arrangements to meet up and get you re-flashed!
    PapaRee and New4x4[QUOTED] like this.
  10. Feb 13, 2021 at 8:01 PM
    #50
    New4x4
    AZ
    The wife is down so PM details and I will mark my calendar.
    PapaRee likes this.
  11. Feb 13, 2021 at 8:34 PM
    #51
    New4x4
    AZ
    @tclavell add me to the list and about what time should I be there? I see @TWTaco will be there around 10ish.
    tclavell[OP], PapaRee and TWTaco like this.
  12. Feb 13, 2021 at 11:25 PM
    #52
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    @TWTaco going to Phx via 10 or northern route I40 then south? I'm up north and working the weekend. So cant make it to down south. If you were going through Flagstaff I'd get it done. If not, next time.
  13. Feb 13, 2021 at 11:43 PM
    #53
    TWTaco
    Dave
    Sorry i will be taking the 10 to and from. Maybe you can get a group going in the Flagstaff area and we can make a tune day happen in Flagstaff!
    PapaRee likes this.
  14. Feb 14, 2021 at 6:23 AM
    #54
    tclavell
    Troy
    Phoenix, AZ
    G70
    Added! Please PM me your phone number and I’ll get you my contact information and address. Plan on being here around 10a
    PapaRee likes this.
  15. Feb 14, 2021 at 2:51 PM
    #55
    m3t5
    m3t5 Member
    2017 MGM TRD OR
    PM’s sent, add me to the list for 2!
    PapaRee likes this.
  16. Feb 14, 2021 at 2:54 PM
    #56
    tclavell
    Troy
    Phoenix, AZ
    G70
    Added :thumbsup:
    PapaRee likes this.
  17. Feb 14, 2021 at 6:27 PM
    #57
    Scott4032
    Scott4032 Well-Known Member
    Michael
    2020 SR5 4x2 V6
    coming soon!
    add me to the list please.
    TWTaco and PapaRee like this.
  18. Feb 14, 2021 at 6:30 PM
    #58
    TWTaco
    Dave
    Glad you could join the group! See you Saturday!:thumbsup:
    PapaRee likes this.
  19. Feb 14, 2021 at 6:47 PM
    #59
    tclavell
    Troy
    Phoenix, AZ
    G70
    Added! Please send @TWTaco you truck info and PM me your contact information and I’ll get you my address and contact information :thumbsup:
    PapaRee likes this.
  20. Feb 14, 2021 at 6:48 PM
    #60
    TWTaco
    Dave
    Done! He sent his info.
    PapaRee and tclavell[QUOTED][OP] like this.
