Ovtune 90 octane?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GPH36, Feb 24, 2019.
  1. Feb 24, 2019 at 6:18 PM
    GPH36
    GPH36 [OP] Well-Known Member
    2019 Black TRD Pro
    Has anyone here used 90 octane fuel with Ovtune? 90 is the highest where I live, and I’m not sure if there’s nothing to gain... Appreciate your input!!
  2. Feb 24, 2019 at 6:21 PM
    Invid
    Invid Well-Known Member
    New Braunfels, Texas
    2016 Tacoma Limited
    Use the 87 tune and that will work fine with 90 octane
    shakerhood, SpeySquatch and GPH36[OP] like this.
  3. Feb 24, 2019 at 6:25 PM
    grueinthebox
    grueinthebox Massive Member
    Texas
    Blazin' Blue 2017 DCSB
    Assume you're somewhere at altitude? Could be wrong but I believe you can treat it like higher octane if so.
  4. Feb 24, 2019 at 6:34 PM
    GPH36
    2019 Black TRD Pro
    Thanks! I live in AK, guessing the cold has something to do with it? Maybe.
  5. Feb 24, 2019 at 8:09 PM
    Oscar I
    Oscar I No longer a toyota driver
    Air density has more to do with it. They say for each 1000 feet over sea level you can add one octane point but this information is on older engines. You can monitor you knock values and timing adjustments and try to run the 91 on 90 tune but if your Knock Correction Learn Value dips or the Knock FeedBack Value is consistently over the base line of -3 deg then you are not seeing any value of running the higher octane because the ECU is retarding the timing which pulls the power you may have added with the tune.
    Simple answer run the 87 tune
  6. Feb 24, 2019 at 8:10 PM
    GPH36
    2019 Black TRD Pro
    Got it. Thanks!!!
  7. Feb 24, 2019 at 8:14 PM
    Oscar I
    Really the big benefit of the OVtune is the transmission tune. I run the 91 currently but Ill be moving to the 87 performance tune and just enjoy the transmission not being retarded anymore.
  8. Feb 24, 2019 at 8:20 PM
    GPH36
    2019 Black TRD Pro
    With the 87 tune, do you find that the shifting is smoother?
  9. Feb 24, 2019 at 8:24 PM
    El Chivo Norteño
    El Chivo Norteño Well-Known Member
    Central Oregon
    2020 White DCLB 4X4 Off-Road
    100% smoother
  10. Feb 24, 2019 at 8:26 PM
    Oscar I
    Smoother on the base(mpg) tune. Performance tune it can be aggressive depending on throttle position
    GPH36[QUOTED][OP] likes this.
