OVTune Tacoma 3.5L Auto - Transmission / Engine - ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 15, 2017.
  1. Nov 7, 2017 at 6:22 AM
    #281
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    If that's what it's going to take :frusty:. Or make a small windows based capturer that stays in the truck and auto flashes every now and then lol
  2. Nov 7, 2017 at 6:25 AM
    #282
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    haha, u crazy man :) no way I'd be bothered with that every few hundred
    miles. Stock ran well for me, I'd just return it stock + ect mode.
  3. Nov 7, 2017 at 6:28 AM
    #283
    MESO
    State of Jefferson
    Stock tune?? I love the power increase with the OV flash, it just seems to be relearning it's wonky throttle/shifting as time goes on. I can deal with it, and ECT mode def helps.
    Reypac24 and bshammer0 like this.
  4. Nov 7, 2017 at 6:32 AM
    #284
    MacMedic
    MacMedic Well-Known Member
    2016 Black Tacoma TRD Sport
    Maybe write a loop that as soon as the learning is done.. it clears the settings and starts the learning process again...
    But what do I know ... I'm not a programer...:bowdown:
    DES2009 likes this.
  5. Nov 7, 2017 at 6:34 AM
    #285
    BlkTaco47
    BlkTaco47 Unhinged
    Hmmm, maybe I won't see it then :fingerscrossed: Never had any issues with the
    shifting/throttle on stock. I've got about 300 miles on the 1.02c-A now.
  6. Nov 7, 2017 at 6:37 AM
    #286
    Scooby24
    Scooby24 Well-Known Member
    Greg
    2017 DCSB OR 4X4
    We have the necessary equipment to download and install techstream....I have version 12 loaded on my laptop that I flash with. It was loaded before windows defender was disabled and it threw no flags. Using Techstream it's a 2 minute process to connect and clear learning if it's bothersome which seems like an easier process than flashing over time.
    If meso creates a solution to do anything, maybe a reset button using that same functionality....though I can't even begin to imagine the hardware/software solution it would take to accomplish that with just pressing a button.
  7. Nov 7, 2017 at 6:42 AM
    #287
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    Can you explain the process in more detail? Like exactly what is required to do this?
  8. Nov 7, 2017 at 6:47 AM
    #288
    Scooby24
    Greg
    2017 DCSB OR 4X4
    Install the software, launch the software, connect to the ECU, go to utilities, use the erase learning utility.
    12-00-127 is the version I'm using. Download link and instructions using google, look for obdii365 blog. Not going to link the actual site here as this is all on you guys if you want to go this route.
  9. Nov 7, 2017 at 6:50 AM
    #289
    MESO
    State of Jefferson
    Wait a second... are you saying inside TS, there is an option to erase the learning procedure??!
  10. Nov 7, 2017 at 7:03 AM
    #290
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    Does this connect with the same hardware interface that OV provides to load the tune?
  11. Nov 7, 2017 at 7:11 AM
    #291
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    It doesn't ERASE the procedure, just resets the learned values (much like disconnecting your negative battery terminal or reflashing)
  12. Nov 7, 2017 at 7:12 AM
    #292
    MESO
    State of Jefferson
    Bummer. Why does this truck have to be so intelligent:/
    bshammer0[QUOTED] likes this.
  13. Nov 7, 2017 at 7:20 AM
    #293
    prohunter4
    prohunter4 Well-Known Member
    South Ga
    2017 BBP TRD Off Road
    Just to be clear, as I am on the fence about purchasing the tune, you can install said tune, but over time because of the way the ECU is designed, it will overwrite it and put you back where you were. Please correct me if I am wrong.
  14. Nov 7, 2017 at 7:25 AM
    #294
    Scooby24
    Greg
    2017 DCSB OR 4X4
    You can't erase the learning PROCEDURE, but you can erase the learned values.
    BlkTaco47 likes this.
  15. Nov 7, 2017 at 7:29 AM
    #295
    Scooby24
    Greg
    2017 DCSB OR 4X4
    That's not correct, as the ECU does make some changes and adaptations to the way the truck shifts and some throttle response, but it is nowhere even close to the way the stock ECU drove. It can be misconstrued as folks are upset the truck still learns and still has variability in the way it drives, but it's not to be equated with stock. This tune on its worst day is a vast improvement over stock on its best day.
    anthony250f likes this.
  16. Nov 7, 2017 at 7:31 AM
    #296
    Scooby24
    Greg
    2017 DCSB OR 4X4
    No, you load techstream only, indicate what hardware standard you're using to connect to the ECU (TIS I think it is) and it directly connects through the same OBDII port connector but doesn't use any of the software that you use to connect to the ECU and load the tune.
  17. Nov 7, 2017 at 7:45 AM
    #297
    MESO
    State of Jefferson
    Correct. I didn't mean my post to come across as if the stock ECU comeplety overwrites the OrangeVirus tune back to stock. The ECU tune is still there and locked in.. I am very happy with that part. It's the throttle response/feedback and shifting pattern that the truck seems to "re-learn" back to the way it wants.
  18. Nov 7, 2017 at 7:47 AM
    #298
    bshammer0
    Brandon
    Nashville, TN
    I would second this. You are never back to anything nearly as bad as stock, but it does trick you into a PERFECT feeling early on where you literally couldn't imagine the truck performing any better in any scenario which can be a bit addicting then things like the shift points degrade as it tries to unlearn those aspects of the tune. Throttle response and power never really degrade for me though and those were 2 of the biggest complaints I had about stock.
    I actually am back to 1.01b now as I feel the learning isn't nearly as pronounced over time on that release. It only touched throttle response and advanced the timing to optimize premium fuel but that alone seems to provide a smarter input for the learning stuff. It never will run as AMAZING as 1.02c after flash but I won't be watching it degrade much over time either.
  19. Nov 7, 2017 at 7:51 AM
    #299
    prohunter4
    South Ga
    Ok. Maybe I read too much into it. It seemed like you were paying 8 bills for a tune that the learning ECU could overwrite. I am tracking now.
  20. Nov 7, 2017 at 7:52 AM
    #300
    prohunter4
    South Ga
    No way that the ECU can be made to not learn and run just the new program ?
    DES2009 likes this.
