OVTune Tacoma 3.5L Auto - Transmission / Engine - ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 15, 2017.
  1. Nov 7, 2017 at 6:50 PM
    #321
    JaTe
    JaTe Well-Known Member
    Maryland
    2017 Tacoma TRD OR DCSB
    If you're asking if the cable ovtune provides could also be used with techstream SW, the answer is yes.
    DES2009[QUOTED] and bshammer0 like this.
  2. Nov 8, 2017 at 4:33 AM
    #322
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    Yes, thanks... that's what I was asking! :thumbsup:
  3. Nov 8, 2017 at 8:31 AM
    #323
    Stoked4
    Stoked4 Well-Known Member
    2017 trd sport DCLB (OVtuned)
    I'm assuming that each calibration kit is specific to one vehicle?
    You can't use it on multiple trucks?
  4. Nov 8, 2017 at 8:36 AM
    #324
    speedtre
    speedtre Well-Known Member
    DirtySouth
    '17 DCLB TRD OR AT 4x4
    My understanding is that the tune itself is truck specific, but the kit can be used to install tunes on an unlimited # of vehicles...you just need to purchase a tune for each individual vehicle.
  5. Nov 8, 2017 at 8:46 AM
    #325
    Stoked4
    Ohhh ok cool
    I'm only seeing the complete kit on ovtuned
    Maybe after an email can I purchase just the tune?
    Chipi3s and speedtre[QUOTED] like this.
  6. Nov 8, 2017 at 8:58 AM
    #326
    Chipi3s
    Chipi3s Does it rub?
    San Diego
    Theres an option to send in your ECU and he will flash it and send it back to you, that way you dont have to purchase the kit. Cons- if you want a different variation of the tune or if the tune is updated which it will be, you will have to send your ECU back to get reflashed.
  7. Nov 8, 2017 at 9:05 AM
    #327
    Stoked4
    I'm hoping to avoid that
    Maybe I can buy a tune and they can send it to me
    I had a Subaru and this was how I was able to drive the car to the tuner after modifications were done
  8. Nov 8, 2017 at 9:13 AM
    #328
    erok81
    erok81 Well-Known Member
    Imposter
    Does anyone’s get stuck in fourth? Mine did it with the ssp and now does it with the tune.
    It will stay in fourth even at light throttle up to almost 5k. Even letting off it won’t shift to fifth. When it’s stuck and around 4k I can flip the lever over to sport and up one and shifts right away.
    Likely my tire size but mine is pretty much the same in drive as without the tune. With the exception of that occasional sticking 4th. However other times it’ll go to 4th at around 30-35 mph (uncorrected) and sub 2k rpm when I’m off the freeway and mid-light throttle.
    I like the tune in sport mode though!
    trdsilver and Chipi3s like this.
  9. Nov 8, 2017 at 9:14 AM
    #329
    Chipi3s
    San Diego
    Well you have two options
    1. Buy the kit and flash your ecu your self.
    2. Take your ecu out and ship it to him so he can flash it.
    The kit makes more sense as the flash seems to be ‘updated’ from time to time to work out the kinks. Then you could just simply flash it your self as tweaks/updates are released
  10. Nov 8, 2017 at 9:18 AM
    #330
    Stoked4
    Right
    My question is can someone with an off-road buy the kit for (16+ auto with crawl mode)
    And I use their unlocked kit to install the (16+ auto) tune on my sport (without crawl mode)
    Ovtune said this earlier
    Our kits are not car locked. You can actually share them with other Tacoma owners, our tunes are locked.
    Chipi3s[QUOTED] likes this.
  11. Nov 8, 2017 at 9:26 AM
    #331
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    you can use one kit for both of your trucks, you just need to purchase an additional file license for the extra truck.
    speedtre and Chipi3s like this.
  12. Nov 8, 2017 at 9:29 AM
    #332
    Stoked4
    Awesome
    Can this be done through your site or is a phone call needed
    A kit was just purchased for an off-road I have a sport
    Getting them done together would be awesome
  13. Nov 8, 2017 at 9:49 AM
    #333
    OVTune
    OVTune
    one you get the kit and do the first truck we can get everything else done very easily over email. Just read the ECUs on both trucks we can invoice you for the other truck.
  14. Nov 8, 2017 at 9:53 AM
    #334
    Glenn_R
    Glenn_R The Unicorn Turd Gen
    Glenn
    17 Tacoma DCSB OR Inferno
    Now that I have >2K on the 1.02C (A) tune my truck with 34" will hold 4th a lot more than it ever did. But I think it is based on what it has learned. I think it is reluctant to shift to 5th because as soon as it does it will need to down shift shortly there after, even with light pedal input.
  15. Nov 8, 2017 at 10:25 AM
    #335
    acemastr
    acemastr Well-Known Member
    Aaron
    Tampa, FL
    2016 Tacoma Limited 2WD AT
    OVTune
    One journey when towing my dirt bike, mostly with cruise control on I could go from 65 to 78mph with the cruise control and it wouldn't change to 5th until I killed cruise control and slowed. Didn't do it on the return trip though.
  16. Nov 8, 2017 at 10:40 AM
    #336
    trdsilver
    trdsilver Well-Known Member
    So Cal
    2016 TRD Sport 4x4
    OVTune, King 2.5", Total Chaos UCA's, Icon RXT Leaf, Icon Rear Bumps, Pelfreybuilt Silders, JL Audio, Cali-Raised LED, Toyo RT 285-70-17
    Mine does this as well. It will hold 4th much much longer than stock. in some cases this is awesome and in other cases its damn annoying. Ultimately, I like that it holds 4th longer. Worst thing I have to do is put it in sport and shift to 5th and all is well again.
  17. Nov 8, 2017 at 10:49 AM
    #337
    Stoked4
    Great
    Thanks
    How much for the tune itself?
  18. Nov 8, 2017 at 11:17 AM
    #338
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    And for those looking for the cost I searched way back in the original alpha thread, and it would be $305 to buy a license alone if you're using someone else's kit.
    speedtre likes this.
  19. Nov 8, 2017 at 11:58 AM
    #339
    Stoked4
    Sounds good to me
  20. Nov 8, 2017 at 12:29 PM
    #340
    Stoked4
    Is this thread the best way to get in touch with you when I'm ready or is the "contact us"
    Link on your website better?
