OVTune Tacoma 3.5L Auto - Transmission / Engine - ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 15, 2017.
  1. Nov 17, 2017 at 10:20 AM
    #461
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    this is my shift map option C
  2. Nov 17, 2017 at 10:22 AM
    #462
    boxerfan
    boxerfan Member
    Max
    2016 tacoma trd sport
    Forgot to mention I,m order #2184 so I have yet to experience the tune. I like others will be glad to see 1.03 and the improvements you are working on. Thanks in advance. Max
  3. Nov 17, 2017 at 10:27 AM
    #463
    boxerfan
    boxerfan Member
    Max
    Good! Do you have the ability to firm up shifts? I believe that would even help longevity. Instead of sloppy upshifts. I sure the manufacturers cater to the (don,t want to feel anything) majority. No more FLACID shifts........
    PEAKIT likes this.
  4. Nov 17, 2017 at 1:41 PM
    #464
    2017TRDpro
    2017TRDpro Well-Known Member
    2017 TRD Pro
    But option C left upshift 5-6 stock. We like to have upshift 1-2 stock, 2-6 upshift control adjusted.
  5. Nov 17, 2017 at 2:27 PM
    #465
    perkj
    perkj Well-Known Member
    @OVTune something I'd be interested in you looking into is to see if there is a way to allow the e-locker to be enabled outside of 4LO only. I'd like to be able to enable it in 4HI and 2wd.
    SC4333 likes this.
  6. Nov 17, 2017 at 6:19 PM
    #466
    sig916
    sig916 Well-Known Member
    I miss my 1st gen locker :pout:
    perkj[QUOTED] likes this.
  7. Nov 17, 2017 at 8:23 PM
    #467
    WNYTACO
    WNYTACO Well-Known Member
    2016 Gray TRD OffRoad DC
    2 Gallon Airtank with Firestone AirRites
    @OVTune Can you have ECT mode turned on by default when starting the truck? If that can't be done can you reverse the mapping so that the non-ECT mode is really the ECT mapping and then when you press the ECT button it switches to the "normal" mapping? Then maybe we can call the ECT mode in that case the "Economy Taco" mode.
    (Sorry to double post this but I thought it this might be more appropriate in here)
    sig916 likes this.
  8. Nov 17, 2017 at 9:02 PM
    #468
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    I didn’t read thru this whole thread, but how expensive is this?
  9. Nov 17, 2017 at 11:04 PM
    #469
    _Bone_
    _Bone_ Well-Known Member
    Beaverton, OR
    2017 quicksand DCSB TRD Off Road
    Thunder Fist[QUOTED] likes this.
  10. Nov 18, 2017 at 4:52 AM
    #470
    boxerfan
    boxerfan Member
    Max
    That,s What I thought I read. "Option C- Gears 2-5 upshift changed. Gear upshift 1-2 stock, 5-6 stock." Option A sounds close but some people think "enhancing the 1-2 shift is not needed. What do I know! Maybe Option A is just the ticket for me. I do hope that You get a handle on the learning problem. I think I remember you saying that some learning is needed. I,m looking forward to more comments your your own experience with a stock tacoma. Read a bit about that on the other thread. Max
  11. Nov 18, 2017 at 7:58 AM
    #471
    PEAKIT
    PEAKIT Well-Known Member
    UT
    24 Off Road long bed Premium Taco.
    OME 888 nitro front, SPC upper arms,B110 rear shocks, Timberen bump stops, extended brake hoses, U bolt flip, sway bar delete, Dakar HD leaf pack with extra leaf, Snug top HD shell, MobTown Skid plate, cooper Maxx 255-85-16 4:88 Nitro gears,Spider trax 1.5 spacers, AirBedz, debadge, Pro grill.
    They turnback on at 40
  12. Nov 18, 2017 at 9:28 AM
    #472
    Stoked4
    Stoked4 Well-Known Member
    2017 trd sport DCLB (OVtuned)
    There's a thread on here for an abs disable
    And something for traction control
    I'll look later
    bshammer0 likes this.
  13. Nov 18, 2017 at 4:22 PM
    #473
    RBaptist
    RBaptist Well-Known Member
    Newnan, Ga
    2017 TRD Sport - Magnetic Grey
    I've been lurking the OV Tune threads for a bit. Couple of things that I am still unclear on. If I flash the ECU with this, do I have to keep reflashing it to override the Toyota 'Learning'? Saw that on one thread, but on another it seems that OVTUNE fixed this?
    Also - if I run the 87 Octane flash and let's say my wife fills my truck up with 89 or 91 octane - what are the consequences?
    TRDOBSESSED and Ray1989 like this.
  14. Nov 18, 2017 at 4:38 PM
    #474
    TRDOBSESSED
    TRDOBSESSED Well-Known Member
    Blair
    Puyallup, Wa.
    2017 TRD ORAC
    OvTuned
    It is recommended to set and forget it...if you have to run a higher octane i don't see how that would hurt.
  15. Nov 18, 2017 at 4:58 PM
    #475
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Reflashing is not recommended, but as the transmission learning still happens to some degree many have reflashed to “reset” to the awesome shifting immediately after flashing. OV knows the remaining piece and is working on addressing so that the learning doesn’t undo the great work he’s done on the transmission behavior. You will never have an issue running higher than tuned octane. You won’t get the same benefits as if you loaded the 91 tune but it will automatically advance the timing.
    PEAKIT likes this.
  16. Nov 18, 2017 at 5:32 PM
    #476
    RBaptist
    Newnan, Ga
    Thanks for the responses - that actually clears it up! So there still is real benefit to flashing it even if the transmission learning fights it a bit. Man I hope they figure that piece out! Love my Tacoma, but Toyota really jacked that piece up! The engine is not the problem as it is used in other vehicles I’ve driven and it’s nearly flawless in those.....
    mfndoc and bshammer0 like this.
  17. Nov 19, 2017 at 6:41 AM
    #477
    treimche
    treimche Well-Known Member
    Fargo, ND
    How about getting rid of the annoying rev when turning the steering wheel while stopped? Pulling into the garage or shop can be tricky since every time I turn the wheel the engine revs up and makes the truck lunge forward. Same with running the A/C while at a stop, the engine revs up and down when the A/C compressor kicks in.
    As others have noted, the addition of a remote starter in the push to start Toyotas is a little annoying. If there is a way around the key validation issue for the push to start versions of this truck, and being required to have the truck shut down upon opening a door when remote started, that would be amazing. I'd pay for that to get done!
    With the transmission shifting debacle, please make it so it stops racing up to 5th gear at 30 mph. Drive is worthless around town when the damn thing constantly gets up into 5th gear. S4 is pretty much required in order to keep the thing from constantly bogging.
  18. Nov 19, 2017 at 8:04 AM
    #478
    rnicholls
    rnicholls Well-Known Member
    2016 TRD OR DCLB
    I'd be so happy to be rid of that rev match bs. I brought it up with OVTune during the early stages (1.01a) as it was very sharp in reverse. It leveled out in reverse enough to not make the lurch, but it's still annoying in all gears.
  19. Nov 19, 2017 at 10:09 AM
    #479
    PEAKIT
    UT
    This makes it annoying in 4wd high trying to manuver on sandstone clifs. Id like that gone too
  20. Nov 19, 2017 at 1:56 PM
    #480
    Yzkiley
    Yzkiley Well-Known Member
    British Columbia, Canada
    2016 MGM Tacoma Sport DCSB MT
    rain guards, hood deflector, oem tonneau, BFG ko2's, led lightbar behind grill, highlift jack mount side rail, husky Xact front & rear mats, bedrug, AFE cold air intake with scoop, TB spacer, Spec U exhaust, Hikari - lumileds Led's, any time backup cam and gps, OV tune 103B, TRD pro grille, Cali raised pod fog lights, ECGS needle bearing, Bilstein 5100's, Low range offroad 3-1 level kit, SPC light racing ctrl arms, spidertraxx 1.25in spacers, Ride right airbags, clazzio seat covers, carrier bearing spacer, diff drop spacer.....
    OV tune.
    I finally want to get in on this tune. Sounds good from all the posts I have been reading. One problem, I went to the site and it says sold out. I really want the Nov discount as well. How do I order this now?
    Thanks,
