OVTune Tacoma 3.5L Auto - Transmission / Engine - ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 15, 2017.
  1. Mar 8, 2018 at 2:47 PM
    #861
    ebbs15
    ebbs15 Lord Winchester
    Brandon
    Spokane Washington
    09 Lexus GX470
    ECM is Engine Control
    TCU is Transmission Control
    you do both
  2. Mar 8, 2018 at 2:47 PM
    #862
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    ECM = for Engine
    TCU = For transmission
    There is a tune for the engine, and a separate tune for the transmission.
    Inferno__Taco likes this.
  3. Mar 8, 2018 at 2:47 PM
    #863
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    It's been a while since I went through the initial licensing process, so I recommend you have a read of OV instructions here:
    https://cdn.shopify.com/s/files/1/0885/5830/files/OV_TACOMA_Instruction_v.2.pdf?9524367266692507156
    ECM refers to the main computer or brain of your truck, and TCU refers to the transmission controller.
    Edit: Oops, sorry Mat :)
  4. Mar 8, 2018 at 2:54 PM
    #864
    SpeySquatch
    2016 TRD OR DCSB
    Okay, man this is confusing to me.
    Let me see if I got this straight.
    You flash the ECM and then you flash the TCU? How come I don't see anything in the instructions about the TCU or did I miss it?
    bshammer0 likes this.
  5. Mar 8, 2018 at 2:55 PM
    #865
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Yes - this tune is the real deal. 1.01 was great at adding some power for premium, a bit smoother, and actually turning the skinny pedal into something that resembled throttle control. It was great. 1.02 was a progression on that but for me wasn't as refined, so I ended up running 1.01 until 1.03 was available and you can DEFINITELY tell the difference having and R&D truck to drive and test with hundreds of files. It's miles above any prior version and is on a different planet from stock in every way.
    Shellshock, jholc21 and MOC221_ like this.
  6. Mar 8, 2018 at 2:56 PM
    #866
    bshammer0
    Brandon
    Nashville, TN
    ECU is where most of the magic happens - this will be the P5-Canbus drop down. The one with "gearbox" in the name from the dropdowns in PCM flash is the "TCU" Seems confusing and the first time it is but it will all come into clarity once you tinker a bit
  7. Mar 8, 2018 at 2:56 PM
    #867
    MOC221_
    Frank
    Now all we need is a M/T R&D truck... oops, wrong thread. I'll show myself out :hattip:
    Shellshock and bshammer0[QUOTED] like this.
  8. Mar 8, 2018 at 2:59 PM
    #868
    SpeySquatch
    2016 TRD OR DCSB
    @bshammer0
    Thanks man, I am glad there is support. When my kit arrives I hope you don't mind if I ask questions if I have trouble.
    Hopefully the process will be ok for me
    MOC221_ likes this.
  9. Mar 8, 2018 at 3:01 PM
    #869
    bshammer0
    Brandon
    Nashville, TN
    No worries. Despite the tone of some of the other threads today :) most folks are quite helpful
  10. Mar 8, 2018 at 3:03 PM
    #870
    SpeySquatch
    2016 TRD OR DCSB
    @MOC221_
    I almost bought the MT, but when I drove it it felt like I was going to snap the stick. I used to own a 2003 manual 4 banger and it was awesome. 2WD and never got stuck once, just keep on it in 2nd....wish i never sold it
    MOC221_ likes this.
  11. Mar 8, 2018 at 3:14 PM
    #871
    itrsteve
    itrsteve Well-Known Member
    NC
    18 LC/15 GT3
    https://www.vmware.com/products/fusion.html
    It's not hard at all, pretty much if you have a Windows Disc then throw it in and then you can run Windows within this product.
    You can get a free 60 day trial from here that should get you what you need. I would be VERY curious but it should work.
  12. Mar 8, 2018 at 3:19 PM
    #872
    bshammer0
    Brandon
    Nashville, TN
    @SpeySquatch if you search Insider Edition on the alpha thread I think @mesojdm was the one who posted up a completely free solution which is what I used and it works just fine. Takes a little tech knowledge but you use VirtualBox which is free and sign up for insider edition windows pro. Other options are likely “cleaner” but that solution will work and won’t cost you a dime
  13. Mar 8, 2018 at 3:20 PM
    #873
    SpeySquatch
    2016 TRD OR DCSB
    @itrsteve @bshammer0
    I got Windows 10 installed on my MAC from one of my friends and he even gave me a key, so all I need is the kit now. Thanks
    bshammer0 and itrsteve like this.
  14. Mar 8, 2018 at 3:26 PM
    #874
    DakoTaco
    DakoTaco Well-Known Member
    North Coast
    2016 MGM OR Tacoma
    Avid front bumper guard OVtune HPS Intake Tube Meso designs counting
    87, as far as I know only one tune currently for autos. Anybody feel free to correct though. Follow @dYL0n videos, turn everything off, 2 presses on the start button. When you load your tune, let it idle for a while to ease the surge we talk about. I had to load it twice and do that, had the best luck loading it in at the coldest temp and letting it idle. But could just be my truck. After that, enjoy
    dYL0n likes this.
  15. Mar 8, 2018 at 3:30 PM
    #875
    wjrichardson
    wjrichardson Well-Known Member
    WI
    2017 TRD/OR/AC
    Its on the first post of the main alpha thread
  16. Mar 8, 2018 at 3:31 PM
    #876
    DakoTaco
    North Coast
    2016 MGM OR Tacoma
    Don't be ruining our tune by telling Toyota. Let them find out on their own, they'll work harder maybe. Plus, what if they hire Mat, he get a nice cooperate gig, he's not going to put up with this sometimes productive, sometimes soap opera, sometimes daycare forum thread
    Bridge4[QUOTED] likes this.
  17. Mar 8, 2018 at 3:34 PM
    #877
    DakoTaco
    North Coast
    2016 MGM OR Tacoma
    If you can jailbreak a Firestick, this is gravy with the instructions & support by Mat or the forum
  18. Mar 8, 2018 at 6:33 PM
    #878
    YotaDriver631
    YotaDriver631 Well-Known Member
    '18 Taco
    Is this tune really worth the almost $800 price tag? My truck drives decent overall and really good in ECT mode which is free and won’t void a portion of my warranty if something goes wrong.
  19. Mar 8, 2018 at 6:37 PM
    #879
    itrsteve
    NC
    18 LC/15 GT3
    I don’t believe this is the thread to debate such. If you delete your post, I’ll delete mine.
  20. Mar 8, 2018 at 6:37 PM
    #880
    ebbs15
    Brandon
    Spokane Washington
    09 Lexus GX470
    Those that have it say yes... but if you're happy with the ETC mode, then just buy @mesojdm 's all time ETC mod. and call it good. I think the truck is ok, in normal... a little better in ETC... but my dongle will be here tomorrow. $800 to make a good truck better is worth it... but that's my opinion...
