OVTune Tacoma 3.5L Auto - Transmission / Engine - ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 15, 2017.
  1. Nov 4, 2018 at 4:16 AM
    #1261
    Ron1965
    Ron1965 Go Bruins.......
    Ron
    Socal
    2018 Cement TRD ORSB PREMIUM/TECH
    OVtune Mooseditty Custom;DD Exhaust;Nitro 5.29’s;SCS Brushed Copper;AFe Custom CAI
    Look at post 1244 above
    See above. “It will climb for you at predetermined shift points”
  2. Nov 4, 2018 at 4:29 AM
    #1262
    catastrofe
    catastrofe Well-Known Member
    Bob
    Montrose, CO
    2022 F350 Tremor
    I interpret that to mean it will shift to keep from over-revving, but it won’t be very driveable. He specifically stated the shifting won’t be ideal for “normal driving”, which implies that it’s not very functional.
    TFly likes this.
  3. Nov 4, 2018 at 6:01 AM
    #1263
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    A good compromise could be S mode ECT off would be like the stock S Mode ECT on and S Mode ECT on would enable shift locking. If that makes any sense.
  4. Nov 4, 2018 at 6:26 AM
    #1264
    catastrofe
    Bob
    Montrose, CO
    2022 F350 Tremor
    The owner’s manual recommends “S” and ECT on for towing. I don’t want to be forced to manually shift while towing for optimal drivability...if I wanted that I would have purchased a MT truck.
  5. Nov 4, 2018 at 6:27 AM
    #1265
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    it is optional.
    DiabloTRD and GPatriot like this.
  6. Nov 4, 2018 at 6:30 AM
    #1266
    catastrofe
    Bob
    Montrose, CO
    2022 F350 Tremor
    Thank you!
  7. Nov 4, 2018 at 6:32 AM
    #1267
    Supr4Lo
    Surprise, AZ
    In my opinion once you modify the truck in any way the manual no longer applies to the modified area of the truck.
  8. Nov 4, 2018 at 6:34 AM
    #1268
    catastrofe
    Bob
    Montrose, CO
    2022 F350 Tremor
    I don’t consider the tune to be a modification...it’s an enhancement. It hasn’t changed basic functionality, just improved it.
  9. Nov 4, 2018 at 6:36 AM
    #1269
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Which is a modification :confused:
  10. Nov 4, 2018 at 6:49 AM
    #1270
    Taco16LB
    Taco16LB Well-Known Member
    Do you have an idea what would happen if someone had a Shift select Pro hooked up to the vehicle and had the shift lock program also ? Would the ssp be canceled or could it cause damage ?
  11. Nov 4, 2018 at 6:50 AM
    #1271
    catastrofe
    Bob
    Montrose, CO
    2022 F350 Tremor
    I’m my mind, improving something doesn’t require modification. Not all modifications improve the original, and all improvements are not modifications.
    Your definition may differ, and that’s fine.
  12. Nov 4, 2018 at 8:31 AM
    #1272
    treimche
    treimche Well-Known Member
    Fargo, ND
    I can try it once this new version of 1.05 is out, still using my Shift Sense Pro once in a while. I think the SSP would just take over the shifting since it is basically simulating what the driver is doing by moving the shift lever.
    Taco16LB[QUOTED] likes this.
  13. Nov 8, 2018 at 8:18 AM
    #1273
    Reganou812
    Reganou812 Member
    Ford F150
    "S" mode and "ECT on" equals manual shift with a couple of safety features, 1. auto downshift to first when stopped at light, 2. auto up shift at really high RPM to prevent over rev.
    Sounds awesome!!! I am so down!!
    I have a honda FIT that I use to commute 90 miles each day. It has a sport mode with paddle shifters. The sport mode functions the same way as the OVTUNE proposal. I really like this feature. It's the way sport mode should work. Let the driver decide which gear and when.
  14. Nov 8, 2018 at 8:23 AM
    #1274
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    Mat,
    How long is the shift delay from when you slap the stick to when the tranny shifts? Is it like a IS350/GS350 paddle shifter, or is it like stock (delayed)?
  15. Nov 8, 2018 at 8:49 AM
    #1275
    fxrman
    fxrman Well-Known Member
    palm springs
    Quicksand 2016 trd double cab off road
    OVT 1.03 Tacoma bed matt Husky floor liners Insain fab aluminum bumper with Baja design s8 30" light bar DB custums grill with Baja design s8 30" light bar
    I might b wrong but I'm running on 1.03 and thought the converter
    Locked in S mode with ECT on or off...??
    Kinda handy...
  16. Nov 15, 2018 at 8:24 AM
    #1276
    SD_SR5
    SD_SR5 Member
    Sean
    2017 Toyota Tacoma SR5 V6
    Another thing to keep in mind is when OVTune is tuning these Trucks he's doing so with no third party items like shift select Pro etc. To be honest after the tune you shouldn't need anything else to enhance the shifts or throttle response. Also it's kind of like asking Borla if you modify your Borla Exhaust with a Magnaflow resonator how will it affect the sounds, they won't know that because they don't have Magnaflow parts laying around to test.
  17. Dec 12, 2018 at 2:39 PM
    #1277
    FishyPete
    FishyPete Member
    Pete
    2017 Tacoma TRD OR
    Anyone have an update on 1.05? Pre Ordered and was under the impression it would be out by now
  18. Dec 12, 2018 at 3:29 PM
    #1278
    Egnaro
    Egnaro Watch this
    Brett
    AZ
    16 Inferno DCSB Offroad 4x4
    Ricochet full skids, Mobtown rear with swing-out, toytec boss 2.0, OV tuned
    1.05 is coming soon. Should be a major announcement end of the week
  19. Dec 13, 2018 at 7:20 AM
    #1279
    Airborne22
    Airborne22 It's tough being a trophy husband
    Glen
    Suffolk, VA
    2018 Trd Off-Road SB Inferno Red
    See my build page!
    So...if someone were to sell their truck, could they also sell their OVtune? I'm not trying to be cheap, I'm just broke and don't have $700.
  20. Dec 13, 2018 at 7:26 AM
    #1280
    2017TRDpro
    2017TRDpro Well-Known Member
    2017 TRD Pro
    Yes, but you'll still need to purchase a new license from OVtune. The combined cost should be still lower than buying direct from OVT.
    Airborne22[QUOTED] likes this.
