OVTune Tacoma 3.5L Auto - Transmission / Engine - ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 15, 2017.
  1. Oct 18, 2017 at 7:52 AM
    #121
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    Well i uploaded the 87 octane tune the other day and stopped for gas last night thinking "sweet, I can run regular now." So i filled up from empty with regular and just as I was putting my cap back on I noticed that it was 85 octane. So of course a facepalm for a second and think about what I'm going to do.
    Well I was running around like crazy and didn't have time to run home to flash to stock so I went for it. I'm happy to report that the engine runs fine with no detectable misfires or stumbles (at least that I can notice, techstream may say differently).
    Granted I will be using mid-grade going forward (88 octane around here) even though I think the elevation (~5,000ft) negates some of the effects of using lower octane I don't want to risk it.
  2. Oct 18, 2017 at 7:58 AM
    #122
    rob4092xx
    rob4092xx Well-Known Member
    Phoenix, AZ
    Yup! Or worse if OVTune were to shut down, go out of biz, or just flat out ignore you!
  3. Oct 18, 2017 at 8:04 AM
    #123
    rob4092xx
    Phoenix, AZ
    OVTune seems like a great guy...I mean this! However, six months from now his priority will no longer be the Tacoma. It will be something new and he may be catering to those customers 24/7 much like he is doing for Tacoma owners right now. Do you really think it would be reasonable to expect him to continually bench flash your ECU for free? Even if it were for free, once he gets a ton of orders in on his next project, do you think your bench re-flash will be his priority? Do you realize your truck cannot be started while the ECU is in transit (or sitting on his shelf while he tends to his latest project customers)? Do you realize if your ECU is lost or sits on the shelf for an extended period that your truck has turned into a pile of metal parts? It isn't like a tire that can be easily or inexpensively replaced.
    Friedtacolover likes this.
  4. Oct 18, 2017 at 8:06 AM
    #124
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Please do not speak for us or what our development plans are, as what you are saying is not only wrong but putting irrational fear in peoples heads.
    I have been tuning Mazdas for several years and I still bench flash them to this day, even though it's not my "main priority"
    if anything like this were to happen we would release out all of our files for everyone.
    HJM2, ebbs15, climbhigher23 and 10 others like this.
  5. Oct 18, 2017 at 8:12 AM
    #125
    rob4092xx
    Phoenix, AZ
    I was not speaking to you or sharing your development plans. I was voicing my opinion with EVERYONE based upon previous experience. Please don't attempt to mute or censor my comments! Sorry I struck a nerve! I wasn't trying to be negative towards you. As I first stated, you seem (seemed?) like a great guy and have delivered excellent customer service.
  6. Oct 18, 2017 at 8:14 AM
    #126
    OVTune
    OVTune
    I am not muting or attempting to.
    " however, in six months from now his priority will no longer be the tacoma"
    How do you know this is? That statement is completely false
    ebbs15 and climbhigher23 like this.
  7. Oct 18, 2017 at 8:14 AM
    #127
    invidious
    invidious Well-Known Member
    San Antonio, TX
    +1, I dont see how thats "voicing my opinion".
  8. Oct 18, 2017 at 8:16 AM
    #128
    rob4092xx
    Phoenix, AZ
    You are absolutely correct. I should have stated, "'may' no longer be the Tacoma." I went back and edited my original comment. Thanks for pointing this out.
  9. Oct 18, 2017 at 8:18 AM
    #129
    Metallikatz3
    SLC, UT
    2017 DCLB OR
    Always in process
    Why is everyone hung up on the bench flashing? This tuning is literally idiot-proof on your computer.
    I've tuned 2 other vehicles using different methods and this is by far the easiest.
    Example 1 - Bullydog tuner for a Tundra. Had to hook up a battery charger to the truck, plug the BD tuner in to the computer, upload files. Plug BD in to the truck and navigate using 2 buttons to select options. Process took over an hour each time I wanted to change something.
    Example 2 - E46 BMW tuning - I pulled an auto trans and put in a manual trans. I had to remote in to a server in Romania to access BMWs factory software while plugged in to the car. Had to edit text files in German for every computer module in the car to remove the automatic transmission programming. Not only was this nerve wracking it was just a pain in the ass.
    Now - OVT. After doing the initial read - maybe 30 min between downloading, setting up my computer, and reading files. Now that I have received new files from Mat the reflash process takes 5 min. Plug in, open the software, select, write, unplug. BOOM
    oranjish likes this.
  10. Oct 18, 2017 at 8:18 AM
    #130
    su.b.rat
    su.b.rat broken truck
    why don't you watch OV activity on Facebook. you'll see he updates stuff all the time. he's a developer who tunes and tweaks his work over time... it's on the net for you to see. assumptions...
  11. Oct 18, 2017 at 8:20 AM
    #131
    VangaSTL
    VangaSTL Well-Known Member
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    So how does this work? If I buy the full $765 kit. Could I flash multiple Tacomas? Or is it somehow licensed to my particular vehicle?
  12. Oct 18, 2017 at 8:22 AM
    #132
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    lol
    Lt_Dan likes this.
  13. Oct 18, 2017 at 8:22 AM
    #133
    rob4092xx
    Phoenix, AZ
    I am certainly not trying to create a pissing match with anyone. I am simply sharing my experience with another company similar to OVTune who reflashed the ECU in my Hummer H3 for $235. Then every time the dealer updated the software (without ever telling me I might add), I lost my tune and had to send it back to be reflashed. Doesn't seem like much of a problem but they suddenly lost interest in reflashing it a third time and kept it for two weeks while my Hummer sat in the garage unable to be driven.
    I will state on the record that based upon what I have followed, OVTune's communication, customer service and product seems heads above that I received for my Hummer. In fact, they are not even close. However, I don't believe it is unreasonable to share my experience with others. I am not implying in anyway that this will be the case with OVTune!
  14. Oct 18, 2017 at 8:23 AM
    #134
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    See this post
    VangaSTL[QUOTED] likes this.
  15. Oct 18, 2017 at 8:23 AM
    #135
    dorton
    dorton rockcreekoverland
    Winston Salem NC
    2016 TRD Off Road
    Old Man Emu Nitro Chargers, CS047R leafs w/ D29XL extra leaf, CBI front and rear bumpers, CBI armor, rock sliders,ditch light brackets, and bed rack, Free Spirit Recreation Extreme Series roof top tent, VTX Viper wheels, General X3 Grabber tires, 4.88 gears front and rear, Kenwood TM-710G UHF/VHF radio. Icom IC-706MKIIG UHF/VHF/HF radio,KC Hilites 20" Flex Bar and ditch lights, Safari snorkel, BedSlide Classic, SnoMaster USA expedition series fridge.
    Sounds pretty negative from where I'm sitting. He's delivered exactly what he's said, and has done more than his share with trying
    to answer every question in the other thread. So far he's been bombarded with orders, and questions, and deserves the benefit of
    the doubt. In six months a lot of things can happen. I don't see the desire for drivability improvements to decline, and that is what's
    steering the ship.
    KTJO 4x4 likes this.
  16. Oct 18, 2017 at 8:28 AM
    #136
    OVTune
    OVTune
    To give you an example of what I did for a market / community that asked for me to do something that was ultimately not a profitable venture for me. (actually lost money in the process).
    I spent a few months developing stuff for the mazdaspeed / mazda proteges EEPROM ecu. After it all most people didn't want it, nor want to purchase it. So then I just released everything I did out so that the community can do whatever with it, then I moved on.
    I'm not perfect. No business is. But I do whatever I am able to.
    Mr. Furley, Skydvrr, riz_atx and 5 others like this.
  17. Oct 18, 2017 at 8:31 AM
    #137
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Dude, don't even waste your time.
    I am 100% positive your actual customers will set this straight.
    I am not a customer, but the guy is going off on a TW tangent and everyone can pick it up but him.
    perkj and KTJO 4x4 like this.
  18. Oct 18, 2017 at 8:34 AM
    #138
    KTJO 4x4
    KTJO 4x4 Well-Known Member
    Katie
    Oregon
    2017 TRD OFF-ROAD 4x4 DCSB BARCELONA RED
    Nitro 4.88 Gears OVTune 1.05 91Oct DirtyDeeds Exhaust
    Can you kindly explain to me the difference between a bench flash verses purchasing the tune itself? Please don’t just say the price
  19. Oct 18, 2017 at 8:40 AM
    #139
    Metallikatz3
    SLC, UT
    2017 DCLB OR
    Always in process
    Details of bench tuning is post #82.
    Purchasing the tune - you will receive an OBDII connector and then tune files by email
    KTJO 4x4[QUOTED] likes this.
  20. Oct 18, 2017 at 8:40 AM
    #140
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    OV has a stellar product and is doubling down on the Tacomas (on all platforms) and it also shares platforms with Lexus and other Toyota (like Camry) platforms so this ECU is here to stay and the demand will continue to be high. Mat's a smart guy, he knows this - Taco owners are rabid with their mods and this is one of the best things anyone can do for their truck's performance - and knows the demand thus far is only the tipping point. Putting fear in people's minds is not helpful when we have a guy who has put his life on hold, developed an incredible product (in wicked short time). Yes, any new product has stumbling blocks to overcome early on to refine the process, meet demand, etc., This happens with anything, and even moreso on something as technical as this.
    He's in this for the long haul - and his pricing reflects this ongoing commitment. You're paying for a relationship and a "subscription" of sorts to support mods, new calibration versions, etc.,
    Reypac24, su.b.rat and perkj like this.
