OVTune worth it?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by oyemengitsamie, Jan 27, 2021.
  1. Jan 28, 2021 at 6:19 AM
    #41
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    71tattooguy[QUOTED] likes this.
  2. Jan 28, 2021 at 6:23 AM
    #42
    215Grappler
    215Grappler Member
    2020 Tacoma Off-road
    I'm getting an OV Tune on my 2020 Off Road this Sunday. Local guy is charging $250, which seems to be the going rate. Looking forward to seeing what it does. Stay tuned (no pun intended).
  3. Jan 28, 2021 at 6:45 AM
    #43
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Oh right, forgot that there is no tune for the 2.7L.
    jeffmansion[QUOTED] likes this.
  4. Jan 28, 2021 at 7:25 AM
    #44
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Man honestly its not hard at all, you need basic computer skills. If you know how to post pics on TW, you are good to go:)
  5. Jan 28, 2021 at 7:28 AM
    #45
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Thanks Brother :fistbump:
    Junkhead[QUOTED] likes this.
  6. Jan 28, 2021 at 7:44 AM
    #46
    bdunna
    bdunna Well-Known Member
    2005 tundra access cab
    My shellshock charged 250, but said updates would be 20$. I've had my truck since 2016. When I first got it it would hesitate sometimes for up to 6-8 seconds from reverse (backing out of a parking spot) to drive. Not only unsafe, but embarrassing. After several failed attempts speaking to the dealer I finally got a tsb printed and took it to the dealer (thanks TW). If updated the Ecu and took care of some issues like not staying in 6th, a few surges, cruise control issue, and the dreaded Reverse to Forward.
    I was still not satisfied with the shift patterns. Last year I considered the pedal commander, but it does not help with shift points. I then considered OV tune, but $800 all in and no at home computer made this impossible. Fast forward Shellschock is in my area and I have him due the Vf tune. Night and day difference. I am very happy with it. Shifts better, more power, usually better gas mileage (same with winter blend and cold truck). This is how the truck should have come stock. Toyota really dropped the ball on this.
    With the pedal commander I would be hesitant due to issues with check engine light. I have no experience with the pedal commander, but it essentially changes the drive by wire inputs. It does not change shifting points, or help to make it run more efficiently. From all the research I have done it looks like the main issue with the pedal commander is people changing the program while driving and not stopping first, it then throws a check engine code. Again, I have never had one. Just repeating what I have seen in Youtube videos.
    I will say that my favorite mod to the truck has been the tune. It is now pleasant to drive.
  7. Jan 29, 2021 at 8:26 AM
    #47
    Lcfj60
    Lcfj60 Active Member
    2022 Tacoma AC MT 4x4 TRD Sport
    I'm gonna go against the grain and say NO, it's not worth it. It makes the truck drive different but it does NOT fix the inherent problems that this engine/transmission combo has. Engine is lacking in low end torque and the transmission is geared improperly. I've tried about 6 different tunes, from the OV 2.0 to various custom tunes uploaded here. Some of the user-tunes help more, but they create other problems like erratic idle, terrible fuel mileage, etc. One tune made the truck more "fun" to drive around town... Until it snowed. The erratic throttle response was scary on slick roads.
    Conclusion, I've gone back to stock.
    vF tuner is well done software but it can't overcome hardware deficiencies.
    Thao_209 likes this.
  8. Jan 29, 2021 at 8:43 AM
    #48
    disk_55FL
    disk_55FL Well-Known Member
    disk
    Buckeye
    '17 TRD Sport MT
    You sir .......... are a rare bird. ( No disrespect intended ) :cheers:
    Junkhead and VaToy like this.
  9. Jan 29, 2021 at 10:51 AM
    #49
    bdunna
    Driving in the snow and ice here in Iowa I have not noticed that at all. I don't have any numbers to back it up, but it feels more responsive and like the torque is there that did not use to be. I don't think the trans and engine are bad at all, just badly tuned. If you had it and didn't like it I am very surprised. I will say if not using 4wd on ice and snow or turning a sharp corner I will hit that lsd/trac button and it doesn't tend to slide around the corner. I believe the lsd works great on dry cement, but not on ice or snow. One wheel spins, starts to slide, the computer kicks in to slow the wheels and you don't really move. My old Tundra was 2wd, but heavier. It would not even take off from a dead start on ice if not warmed up where the idle kicked down. Once warmed up you really needed to creep out in a straight line, a slight angle and if would slip all over. You couldn't play with the trac/lsd either.
    disk_55FL likes this.
  10. Jan 29, 2021 at 10:55 AM
    #50
    TacoTimo
    TacoTimo Well-Known Member
    Timo
    2019 TRD OR 4x4 Cav. Blue
    So seeing that people kind of have mixed reviews and it's not an end all, be all solution, is there a combination of getting an OV tune plus doing a gear swap and so on and so forth that seems to be THE combo that solves drivability issues from the factory? Or am I going to have to pony up and do a Supercharger as well?
  11. Jan 29, 2021 at 11:14 AM
    #51
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    Didn't people independently verify on a dyno that there was a gain up to 40 ft/lbs of torque in the lower end? Not peak torque, not an increase where it needed it.
    Junkhead likes this.
  12. Jan 29, 2021 at 1:23 PM
    #52
    DawgLover
    DawgLover Well-Known Member
    Jordan
    McDonough, GA
    2020 Cement SR5 DCSB
    Leather, TRD cat-back performance exhaust, Predator side steps, black overlays, 4R TRD Pro wheels, Nitto Terra Grappler G2s 265/70/17, TRD Pro shift knob, bed mat, Diamondback SE, TRD Pro grille, OV Tune, interior LEDs
    I've read a few posts that state the difference for the OV Tune on 2020s and 2021s is not as profound. Can someone with a 2020 or 2021 vouch that the tune is worth it?
    Every post on here stating that it is worth it was written by someone with a 2019 or older.
  13. Jan 29, 2021 at 6:50 PM
    #53
    TacoTimo
    Timo
    The 2020 Tacoma TRD-S I rented on a trip had a vastly better ECU tune on it compared to my 2019 TRDOR, for what it's worth.
    DawgLover and 71tattooguy like this.
  14. Jan 29, 2021 at 7:34 PM
    #54
    dragdoc
    dragdoc Member
    Todd
    2018 TRD offroad manual trans
    Stock so far!
    I am interested in the tuning for my ‘18 manual trans truck but a bit confused.
    “Local people” doing the tune? What is meant by this? Charging $125-250 to install the tune on top of the $800 for the OV program?
  15. Jan 29, 2021 at 7:37 PM
    #55
    MGMSangTaco
    MGMSangTaco Colorado Toyota Tuning
    Denver, CO
    2017 TRD OR MGM DCLB
    Honestly I waited way too long, I’m surprised this is even a question anymore. Vftune makes the truck a whole new truck, literally the best money I have spent on it. If you’re in CO and need a tune PM me.
    I ask for one $250 donation for the first tune and then from then on free adjustments or tweaks if people ever make changes.
    Junkhead and SELAroadrunner like this.
  16. Jan 29, 2021 at 7:46 PM
    #56
    TacoTimo
    Timo
    Want to elaborate on that a bit? I'm in PHX and travel up that way semi often.
  17. Jan 29, 2021 at 9:50 PM
    #57
    dragdoc
    dragdoc Member
    Todd
    Stock so far!
    I am in NW suburbs of Chicago
    Is this “vftune” a competing product to the ovtune (orange virus, right?)??? If So I buy the tune for $XXX and them someone like yourself gets $250 for initial install and updates?
    sorry not following this too well
  18. Jan 29, 2021 at 10:19 PM
    #58
    MadKatt
    MadKatt In need of serious help..
    Frozen Midwest Tundra
    2019 TRD OR DCLB Calvary Blue
    Personally would not consider OVtune. I did pedal commander for over a year and had no issues with it. But Toyota put out that new update and my 2019 runs perfect sold the PC and have had no issues or complaints on how my truck performs.
  19. Jan 29, 2021 at 11:35 PM
    #59
    Thao_209
    Thao_209 Well-Known Member
    2017 Tacoma TRD
    Stock
    I totally agree with you, I went back to stock and never looked back. Had the dealer flash an updated tune (04b04) and it drove a lot better, no crazy idle and no other issues. Sold my dongle kit last year with no regrets. One of the biggest reason why I sold it was because of the immaturity and lack of professionalism from Matt.
    GreyBaldTaco likes this.
  20. Jan 30, 2021 at 5:09 AM
    #60
    TacoTimo
    Timo
    Is there a factory update for a 2019 model year truck? Wondering if this is what I'm looking for, because the 2020 I drove was considerably better and more refined in the tune when compared to my 2019.
