Ow/20 Oil Weight
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dblcabber, Mar 31, 2016.
  1. Mar 31, 2016 at 7:18 AM
    Dblcabber
    Dblcabber [OP] Active Member
    DCLB
    Sweet air freshener, installed march 2008
    I drained and replaced my engine oil last night. I've never used 0W-20 before, but holy lord almighty, that stuff seems to be ridiculously thin. Looking at the owner's manual, it says something to the effect that using 5w-20 would be fine, but if you do, you have to put 0w-20 back in at the next interval.
    I get that in order to hit the advertised MPG, you probably need to use the recommended weight, but lets be honest, AINT NOBODY GETTIN THE ADVERTISED MPG. With that being said, I live in the southeast where we don't really know what winter feels like....you think I'd be wrong/crazy to use a thicker weight? Or should I stop worrying because in the grand scheme this ultra thin fully synthetic stuff is A-OK....
  2. Mar 31, 2016 at 7:20 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    I've used 0w20 synthetic for years in my Honda Civic and when I had my 2008 Tacoma 2.7. Never had an issue.
  3. Mar 31, 2016 at 7:27 AM
    OnceARunner
    OnceARunner War Eagle!
    Georgia
    2016 DCSB TRD Sport Tacoma
    Unless I'm reading the owners manual wrong, it doesn't say that you have to switch back. It just says that you need to change every 5k if you are using 5w-20 whereas the 0w-20 can go 10k between changes.
  4. Mar 31, 2016 at 7:32 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    5w-20 blend or dino maybe but why would interval be any different for 0-20 vs 5-20 full syn?
  5. Mar 31, 2016 at 7:33 AM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    Auto manufacturers actually spend quite a bit of time, money, effort, thrashing their automobiles to figure out what the best oil to use is. I've talked with people that worked on Lubrication Testing at a major auto maker.... when they have an oil recommendation, it is no BS. I consider myself a pretty smart fella, but I don't have the knowledge to recommend something "better" than what Toyota recommended. If you want to be an oil guinea pig, you can take that risk..... but you can bet Toyota already tested 5W-20 and has a good idea what the best oil to use would be.
    I'd just use what the manufacturer recommends.
    smitty99, Hobbs, SpaceTaco and 4 others like this.
  6. Mar 31, 2016 at 7:41 AM
    Woodrow F Call
    Colorful Colorado
    Here is a pretty good explanation of what the numbers actually mean...... http://www.driverstechnology.co.uk/oils.htm
    In short:
    As far as 0W-20 and 5W-20 @100C, both oils should exhibit the same viscosity. @ winter temperatures (cold start), the 0W-20 will be a little thinner (which is a good thing).
    NAAC3TACO likes this.
  7. Mar 31, 2016 at 7:50 AM
    Dblcabber
    DCLB
    Thanks man-I thought about that. Watching that stuff just come screaming out was a bit of a shock-I'm so use to watching it drain out in a much darker color from a much older engine...
  8. Mar 31, 2016 at 7:52 AM
    OnceARunner
    Georgia
    couldn't tell you. I'm just repeating what the manual says. For the normal schedule (not severe) there is no mention of an oil change at 5k since it comes with 0-20 from factory. The first time it says to change the oil is 10k. Then at 15k, it has this: Note: If 0W-20 oil WAS NOT used at the last oil change, replace engine oil and oil filter."...meaning after 5k. It says that for every interval of 15, 25, 35, etc.
    Basically it says to replace every 10k if you stick with 0-20 and do it every 5k if you use 5-20. That may be simply because 5-20 is available as traditional and 0-20 is always synthetic.
  9. Mar 31, 2016 at 7:55 AM
    RCRcer
    RCRcer Well-Known Member
    2015 OR DC
  10. Mar 31, 2016 at 8:57 AM
    LEBM
    LEBM Thread Killer
    Eleanor, WV
    2021 TRD PRO 6MT Midnight Black
    Used oil analyses on high mileage engines running 0w-20 are coming out just fine. No worries.
    Clearwater Bill and smitty99 like this.
  11. Mar 31, 2016 at 9:12 AM
    evilfij
    evilfij Well-Known Member
    2016 ACLB SR 4x4 MT Utility Package Black
    TRDOR wheels, sheepskin seat, cruise and intermittent wipers, curt hitch
    Once I am out of warranty I am running 5w30 or 0w40/5w40
  12. Mar 31, 2016 at 9:18 AM
    LEBM
    LEBM Thread Killer
    Eleanor, WV
    Why?
  13. Mar 31, 2016 at 10:08 AM
    Js16taco
    Js16taco Well-Known Member
    2016 Tacoma trd sport
    People don't understand that newer engines have much tighter tolerances than ten years ago. Using a thicker oil will only cause more friction in the engine... 0w-20 is just fine.. Some cars are now using 0w-10
    RitchieE24, Hobbs, CusterFan and 2 others like this.
  14. Mar 31, 2016 at 12:54 PM
    evilfij
    Margin of error and that would help me by not requiring me to keep another weight of oil around. The 2.7 used to be speced for 5w30 if I am correct and I don't see any reason why it would cause any issues other than maybe some very small decrease in miles per gallon. If it taps or something I will go back to 0w20.
  15. Mar 31, 2016 at 1:05 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Tighter tolerances need lighter oil....if not you get wear cuz heavier oil don't get in there as easy as lighter oil...!!
    Simple as dat..! Heavier oil in this engine is not smart.
    RitchieE24 and Herniator like this.
  16. Mar 31, 2016 at 1:09 PM
    evilfij
    Tighter tolerances in what? Bearings? I am happy to be convinced otherwise, but I don't see how 0w20 was anything other than a way to eek out a little better mpg.
  17. Mar 31, 2016 at 1:15 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    whopper and RitchieE24 like this.
  18. Mar 31, 2016 at 1:21 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Read the link in post #9.
  19. Mar 31, 2016 at 1:31 PM
    renau001
    renau001 Well-Known Member
    I've never understood the concern of this oil seems too thin when I drain it out. I agree, it is definitely thinner than what most are used to. But how thick do ya'll think 5w-20 is at 180 degrees? Oil is pretty thin once it warms up. And it's not a bad thing that it's thin when it's cold. If you're debating 5w-20 vs 0w-20, don't. Most 5w-20's are not any thicker at operating temps unless you get redline or a euro formula or something like that which do not meet the ILSAC GF-5 spec called for. If you have special operating conditions that warrant a thicker oil because you typically run higher engine temps, you probably already know who you are. If you're not sure, use what the mfr recommends.
  20. Apr 1, 2016 at 6:07 AM
    SilverII
    SilverII Well-Known Member
    DFW
    2016 Tacoma Limited 4x4 Blue
    wal-mart has these mobile 1 0w-20 for $22.xx on sale
    CusterFan likes this.
