Owl-Like Hooting Noise Accelerating from a Stop
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Commocean, Dec 3, 2020.
  1. Dec 3, 2020 at 6:19 AM
    Commocean
    Commocean [OP] Well-Known Member
    St. Petersburg, FL
    2023 Tacoma SR5 DCSB 2.7L Ice Cap
    Not sure if this is the same noise/sound that's been indicated in other inquiries, so I'll go ahead and ask. I took a 2.5 hour trip in the truck, and when I came off the freeway and accelerated from the first light I stopped at, I heard a "hooting" sound that seem to pulse with the speed of the vehicle. It lasts a couple of seconds then stops. Did it all the way on surface streets until I reached my first destination. The truck was parked for a couple of hours, and when I drove off, the noise seemed to have gone away. I need to listen over the next couple of days, but I'm pretty sure this is going to be nearly impossible to replicate for the dealer.
    Anyone had such a noise? Any clue as to the cause?
  2. Dec 3, 2020 at 6:31 AM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    2017? I'd bet you need the lower control arms capped. Early 3rd gens made kazoo noises. There is a TSB for it where they instal plastic caps to cover the holes.
    Crawl under your truck and snap a pic of the A arms and post it up.
    Junkhead likes this.
  3. Dec 3, 2020 at 6:35 AM
    Lt. Dangle
    Ohio
  4. Dec 3, 2020 at 6:54 AM
    Commocean
    St. Petersburg, FL
    I don't think that's what's causing the sound. It only does it when slowly accelerating from a stop, and it's never done it until I took the 2.5 hour road trip with the truck. It happens between 0-5mph, so I don't think there's enough air going across the control arms for that to be the cause. Also, it pulses with the speed of the truck while accelerating, like a brake caliper would, only it's a hooting-like sound.
  5. Dec 3, 2020 at 6:59 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Sounds like u-joints to me.
  6. Dec 3, 2020 at 7:00 AM
    Lt. Dangle
    Ohio
    It's not just dependent on vehicle speed. Air speed is what does it. Even if it's not it, I would check to see if your A arms are capped, I had mine covered with duct tape at one point. Has your truck had the TSB done?
    Super easy to eliminate one known source of a noise on these trucks.
  7. Dec 3, 2020 at 7:10 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    You have checked for owls, haven't you?
  8. Dec 3, 2020 at 7:11 AM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    It's time for some Chicken Wangs!
    BillsSR5 likes this.
  9. Dec 3, 2020 at 7:15 AM
    xola3que
    xola3que Well-Known Member
    Long Valley, NJ
    2019 Tacoma Sport
  10. Dec 3, 2020 at 7:21 AM
    mhornco
    mhornco Well-Known Member
    I get that same sound once in a while as well, but it does not always occur. It is not real loud but does have that hooting sound. Thinking it is a harmonic somewhere as it fades out pretty quick, lasting maybe 1-3 seconds. Off and on I have heard it for over 40k miles now so I am pretty sure it is nothing serious. Not enough to make me worry about it.
  11. Dec 3, 2020 at 7:26 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    wow interesting, and then the hooting noise went magically away! amazing these 3rd gens
  12. Dec 3, 2020 at 7:58 AM
    skiploder
    skiploder Well-Known Member
    Somewhere NE of Kanab
    FZJ80/XJ LS swap
    Occam's razor.
    CrazyAirborne likes this.
