owners manual, 4x4 question?
Discussion in '1st Gen. Tacomas (1995-2004)' started by bhh2000, Dec 18, 2010.
  1. Dec 18, 2010 at 1:10 PM
    bhh2000
    bhh2000 [OP] Well-Known Member
    Ben
    Santa Rosa
    2016 DCLB TRD 4X4
    Hi, I recently got my first taco and am very happy with it! but had a questions about the 4x4 system in. My last truck a GMC had electronic 4x4 and I knew I could put it in to 4hi at any speed under about 60. but how does it work with the lever in the Tacoma? do I have to be stopped? or can I do it at any speed?
    I would of looked it up the the owners manual but I am the third owner and I don't have it so if anyone has a PDF of one for a 1996 SR5 I would appreciate it if you could post it.
    Thanks.
  2. Dec 18, 2010 at 2:50 PM
    goomba
    goomba It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    You can shift into 4H only if you are under 50 mph. You can shift out of 4H to 2H at any speed as long as you keep up your speed or slightly speed up. If you want to go into 4L you have to be stooped and in neutral with your foot off the break and not moving.
    It could sound like it is slamming out of 4H of 4L if you have not used the 4wd in a long time. Toyota recommends you drive in 4wd 10 miles every month so your 4wd drive-train stays lubed up.
    EDIT: had to change speed to engage 4WD because if you have a leaver with no button you have to be going less than 50 mph to engage it.
    If you have a button you can be going 62 and under to engage 4WD. That is the only difference.
  3. Dec 18, 2010 at 2:52 PM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    I always stop and put it on N, then i'll switch it to HI4
  4. Dec 18, 2010 at 2:57 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    The OP has a 1996... are you sure? If he has an ADD perhaps... If he has manual hubs, then maybe not.
    Isn't there a web site that has all the old Tacoma manuals online to see?
  5. Dec 18, 2010 at 3:00 PM
    goomba
    Josh
    San Antonio Fl
    ^^ ya if you have hubs you have to be going 25mph or less to engage 4WD. Sorry.
  6. Dec 19, 2010 at 12:06 AM
    BoostingMS6
    BoostingMS6 Well-Known Member
    Alex
    El Paso, TX
    1995.5 Tacoma Xtra Cab V6
    Whaaaaaat? :confused:
  7. Dec 19, 2010 at 12:15 AM
    tacomadude18
    tacomadude18 18 Tacoma Cement
    Carlos
    Midland TX
    TRD Off Road DCLB
    K&N cold air intake
    wait so at any speed under 50 mph u can swith to 2 Wd. ( in other words if you were on 4hi)
  8. Dec 19, 2010 at 1:28 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    You should be able to go onto toyotaowners.com and register a new account with your VIN and then download the PDF of the owners manual for your specific year.
    Also, you can get a two day license for complete online access to all the service guides for $15. They're not in a format that makes for convenient downloading, but it's good to know if you're taking on a major (or minor) job and want the most complete info.
  9. Dec 19, 2010 at 2:11 AM
    Unknown
    Brian
    Los Angeles
    Unknown
    Unknown
    I have the owners manual, let me read it and ill let you know, btw mines a 95.5 so its the same .
  10. Dec 19, 2010 at 12:36 PM
    bhh2000
    Ben
    Santa Rosa
    2016 DCLB TRD 4X4
    Thanks guys I'll go get the manual from toyotaowners.com.
    I'm new to 4x4 trucks, I'm 16 and this is only my second vehicle what does manual hubs mean??
  11. Dec 19, 2010 at 1:19 PM
    BoostingMS6
    Alex
    El Paso, TX
    Manual versus automatic locking hubs. Manual hubs you have to get out of the truck, pop off the little hub caps, then switch the hubs to lock. Takes all of 5 seconds to do.
    Welcome to TW. Got an awesome truck at your age :)
  12. Dec 19, 2010 at 1:40 PM
    David K
    There's plenty to read up... I will be happy to give you some tips or info on the various parts of four wheeling... It is a great world!
    HUBS:
    In short, to save wear and tear on the front drive parts and get better gas mileage, while you are in 2WD you can 'free-up' the front drive parts. In 2WD your rear tires do the driving... in 4WD you add in the front tires.
    To free up the front parts from rotating needlessly, locking 'hubs' are added (in the center of each front wheel at the end of the axle is a dial you rotate from lock to unlock free the front end up).
    Because some folks didn't want to get out and manually lock their hubs, 'automatic hubs' were invented... they would lock at the same time as you put the truck into 4WD. However, to unlock them... you had to drive in reverse a bit.
    A few years ago a newer system was invented called an ADD (Automatic locking Differential)... It still frees up most of the front drive parts and doesn't require backing up to dis-engage. This allows 'shift-on-the-fly' into and out of 4WD (high range).
    So, if you have locking hubs, you will need to go out and turn BOTH of them to lock before going into 4WD, and should unlock them when you are done four wheeling.
    If there is nothing on your front wheels to dial or rotate, then you probably have an ADD. Only the old WWII Jeeps seem to have non-locking hubs, so I doubt your truck is missing locking hubs or doesn't have an ADD.
  13. Dec 19, 2010 at 1:51 PM
    Unknown
    Brian
    Los Angeles
    Unknown
    Unknown
    are you auto or stick?
  14. Dec 19, 2010 at 2:01 PM
    David K
    easier to read?
  15. Dec 19, 2010 at 2:12 PM
    Unknown
    Brian
    Los Angeles
    Unknown
    Unknown
    I rather just type it here...
    Shifting procedures (Lever/button type with automatic transmission)
    SHIFTING BETWEEN "H2" AND "H4"
    To shift from "H2" to "H4", reduce your speed to less then 100 km/h (62MPH) and "4WD" button.
    If the indicator light does not come on when you push in the "4WD" button, drive straight ahead while accelerating or decelerating.
    If the indicator light flashes and the buzzer sounds when you push in the "4WD" button, reduce your speed or stop the vehicle and reset.
    In extremely cold conditions, the transfer may not shift even if you push in the "4WD" button while driving. This is to protect the transfers. Stop the vehicle and try again.
    Page 69
  16. Dec 20, 2010 at 6:20 AM
    goomba
    Josh
    San Antonio Fl
    No you can be going at any speed if you are to shift out of 4H.
  17. Dec 20, 2010 at 8:46 AM
    David K
    What is the difference between shifting OUT of H4 or shifting into 2WD??? Isn't that the same thing?
    Remember to note the YEAR of his truck... he may not have the ADD (shift-on-the-fly) and the older 25 mph or less instructions posted above might apply.
  18. Dec 20, 2010 at 8:50 AM
    98tacoma27
    Ben
    Not Beech Creek
    These are free.
