Oxidation or mold on window trim?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MudFlap, Apr 29, 2020.
  1. Apr 30, 2020 at 4:36 AM
    scott_b
    scott_b Well-Known Member
    The Old North State
    '12 TRD Sport AC MT
    A while back I was trying to find a way to get this crap off as well. One of the best (worst) remedy's I saw on YouTube was a guy used motor oil and sand paper to remove it. Seriously.
    I ended up just replacing the ones on the front windows - they're not that expensive and you can change them in about 5 minutes. I guess I'll live with the rear window. I have a camper top now, so out of sight out of mind.
  2. Apr 30, 2020 at 4:38 AM
    Joker8824
    Joker8824 Well-Known Member
    2014 MGM DCSB TRD Sport
    Interesting to see this as I was just looking at mine last night wondering what to clean it with.....looks like vinegar may be a good choice then hit it with some back to black protection maybe?
  3. Apr 30, 2020 at 8:16 AM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    I used scotch brite, worked pretty well.
    Make sure to tape off the glass and paint so it does not get scratched
  4. Apr 30, 2020 at 8:27 AM
    IL Capo
    IL Capo Well-Known Member
    Sidney BC Canada
    In the trade....for mold abatement you put a dab of bleach on a Qtip and test the area. If the are stays black its not mold.....anyway you look at it you will need to clean the area and remove any debris from the area. Check the surface area for integrity and repair/restore as required.
  5. Apr 30, 2020 at 9:46 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I made a mixture of vinegar and a little water in a spray bottle and sprayed mine this morning and let it sit for an hour and then repeated about an hour latter, then wiped with a paper towel with more vinegar.
    The paper towel had all this black and green crud on it and quite a bit came off. I’m going to repeat the process until it’s all gone and then apply either 303 or silicone.
  6. Apr 30, 2020 at 9:48 AM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    Got mine off with Armor All protectant wipes.
  7. Apr 30, 2020 at 12:08 PM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    Remember when we had metal trim pieces?
    DES2009 likes this.
  8. Apr 30, 2020 at 12:16 PM
    spitdog
    Yes, that would have been my 68 Chevy El Camino :burnrubber:
    Skyway[QUOTED] likes this.
  9. Apr 30, 2020 at 3:57 PM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    Have to try vinegar my molding looks bad also . I did try the magic eraser before and it helped
  10. May 1, 2020 at 1:00 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Use a cleaner (vinegar or I used Simple Green) and 3M dark red/maroon colored pad and it comes off and leaves the rubber smooth and consistent look ready for some Back to Black. Tape on paint to protect it and if you fold the pad its easy to stay on the rubber.
  11. May 1, 2020 at 3:42 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    You will find that Back to Black (and 303 Aerospace Protectant) will come off in the next wash or rain storm. Ask me how I know that.
    spitdog likes this.
  12. May 1, 2020 at 4:26 AM
    spitdog
    I agree, I had used 303 on that area before, trying to stop it from getting worse. It really never worked good because it didn’t last. I think this time I will try silicone from a tube and rub it in real good. I have some silicone that is used on pool plumbing so I will give that a go.
  13. May 1, 2020 at 4:42 AM
    HeavyLifter
    HeavyLifter Well-Known Member
    Jeff
    Athens, Ohio
    2013 TRD Sport
    This has been bothering me for some time. Sounds like some good suggestions but no definitive answer/process. Let’s all update this thread as we work on our trim.
  14. May 1, 2020 at 11:40 AM
    Skyway
    Ande'
    St.Pete
    Vaseline. or other petroleum jelly won't wash off as quickly.
    same as back to black just costs less
    Biscuits likes this.
  15. May 1, 2020 at 7:50 PM
    #35
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Had for years.
    Tried different things.
    I’ve made it look better, but it just comes back.
    I leave it alone now. It’s like the more time you spend making it look “better”.
    The faster it comes back? :itllbuffout:
    Skyway likes this.
  16. May 1, 2020 at 7:51 PM
    #36
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    I have the same problem on my truck...
  17. May 2, 2020 at 8:50 PM
    #37
    Mugsy19
    Mugsy19 Member
    Mark
    2015 Silver Tacoma TRD Sport Pro
    Adams Polishes Tire & Rubber Cleaner. Worked great!
    Biscuits and Skyway like this.
