Oxidized Front Toyota Emblem In Grill
Discussion in 'Detailing' started by TerryTaT, Mar 31, 2025.
  1. Mar 31, 2025 at 12:23 PM
    TerryTaT
    TerryTaT [OP] Active Member
    Terry
    White 2020 Tacoma TRD Sport
    Lot's of subtle things along with All Terrain Tires. Just enough to keep it very clean but subtly different than any others I've seen.
    I have a 2020 Tacoma. I bought it used 2 years ago and now the logo is oxidizing like a cheap plastic headlight. It's getting bad. I've seen a lot of different methods posted online how to address this but am wondering if any of you have found yourself in a similar situation? If so how did you successfully clean it up? I'd like to avoid having to purchase a new one. I'm sure it's insanely expensive.
  2. Mar 31, 2025 at 12:30 PM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Sierra Denali Ultimate, 6.2
    A few additions to make me feel cool.
    Several people make overlays for them. They are normally in the $20 range but it is just a sticker. Your other option is to wet sand it with 500ish grit up to about 2,000 grit. That will remove the oxidation and then you can polish and reseal with clear coat. Looks like they run about $140 for new oem.
  3. Mar 31, 2025 at 12:42 PM
    TerryTaT
    Terry
    Thank you for your input!! When you say clear coat are you talking about a wax/sealant?
    I'll have to give that a try!!!
    As far as decals, I'm not a big sticker fan but if it looks really good I may be swayed.
    Is there a link that I could go to see how they look? Thanks in advance!
  4. Mar 31, 2025 at 12:49 PM
    JJ Customs
    Jay
    NV
    For the clear, I would use an automotive grade rattle can clear that can be found at any local parts store. Keep in mind that you should expect to spend at least $50 for these supplies to do this. To polish you will want a buffing wheel that goes on your drill at a min. After sanding it will be tough to get it to shine by hand. This would work best if you remove the emblem and if you do not clear it when you are done it will not take it long to get worse than it is now. Or, if you want to spend a little more the Cerakote clear holds up well.
    Actually if you decide to sand it. This is your best route. Less than $20 and should give you everything you need to clean that up and clear it. I would go this route an see how you like it. If you don't then look at getting an overlay and this will at least provide a better surface for that to laydown anyway. Win, win.... But, keep in mind you can source a used one in good shape on ebay for the $50 range but you know it is just a matter of time before it turns out the same as the one you have now.
    https://www.amazon.com/CERAKOTE-Ceramic-Headlight-Restoration-Kit/dp/B084RQKLV8?dib=eyJ2IjoiMSJ9.wFTnIKmJiLqv1jjphctuCgYh42OncU5JCVZcdXpXW1u6EGAHEf6ZMhj9OiwxJ5kj95HW8YYYV4RlWI6MysNJlM9DOQtv7jhBcjI0SbkDbQNafbH48TGRp4FP5uGv6ROeUDdiTpqZCu2SIFYq2GaySXBIjWamzq4o0cmfHdV0u76vE33hmud-qPsLa5cotsRkMWm9trtJJQU-JM0KzaawpY7iHRncpgXvszpPzJJGcK4.Hq7oY9n042olcmt1Is5mXAIyNIvuFh-RjmKmhjpA_rE&dib_tag=se&hvadid=694629673107&hvdev=c&hvexpln=67&hvlocphy=9191442&hvnetw=g&hvocijid=16463467386999720977--&hvqmt=e&hvrand=16463467386999720977&hvtargid=kwd-897944727839&hydadcr=7438_13184017&keywords=cerakote+headlight+restoration+kit&mcid=5612ea4c44ab3378923c5493f4db469c&qid=1743451062&sr=8-1&th=1
    https://www.etsy.com/listing/152211...MipINpPZgFyQmgxna6L_vacUK1hrNUcxoCdCIQAvD_BwE
    https://www.etsy.com/listing/1540412929/2018-2023-toyota-tacoma-grey-striped?ls=r&external=1&rec_type=ss&ref=pla_similar_listing_top-2&content_source=8eeb1ed046b06b33d26992ec1ea25ff80c89605f%3A1540412929&logging_key=8eeb1ed046b06b33d26992ec1ea25ff80c89605f%3A1540412929
  5. Mar 31, 2025 at 1:26 PM
    TerryTaT
    Terry
    Thank you very much for your time and insight! I really appreciate it!
  6. Mar 31, 2025 at 1:58 PM
    JJ Customs
    Jay
    NV
    No problem, good luck.
