Oxygen sencor being a mofo
Discussion in 'Technical Chat' started by Trapper6speed, Jul 19, 2010.
  1. Jul 19, 2010 at 5:10 PM
    Trapper6speed
    Trapper6speed [OP] Hacksaw engineer
    Stock
    It started to back out now I can't get it to budge. Before I chop it off. Anyone have any tricks? You just don't have any room.
  2. Jul 20, 2010 at 2:43 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I'm confused.....need clarification.
    Are you saying it started to come out but now its tight?
    The threads on the inside are probably rusted up & dirty. That's why it won't come out. Did you spray PB Blaster (penetrating lubricant) in there? Spray & wait 15 minutes. Spray & wait 15 minutes. Try again.
    You can also try alternating.....Spray, loosen, spray, tighten, spray, loosen, spray, tighten.... This will hopefully work the lubrication in there enough to breakup the dirt/rust.
    Good Luck!
  3. Jul 20, 2010 at 4:37 AM
    Trapper6speed
    Stock
    Ya I'm going to keep trying that. It started back out then it stopped. Must be the rust.
  4. Jul 20, 2010 at 5:18 AM
    My68ur8trd
    My68ur8trd Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
    the are notorious for binding in the 2nd gens
    the loosen, soak, tighten, soak method should work
    dont force it, because you will destroy the threads on the sensor.
    and they are not cheap
    Justin
  5. Jul 20, 2010 at 6:52 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Carefully heat with torch(mapp or acetylene), quench with water, try to loosen, repeat if not.
    Sometimes they'll come out hot, sometimes a combo of Blaster and heat works. Don't force it. Patience wins the day.
  6. Jul 20, 2010 at 7:16 PM
    Trapper6speed
    Stock
    Ahh I got in a hurry and grabbed the impacto. It cam out but made it hard to thread in without a thread chaser. Yea no codes. The #2 bank will not be fun in the future.
  7. Jul 20, 2010 at 7:27 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Use some copper antiseize on the new ones. It'll help down the road!
  8. Jul 21, 2010 at 1:08 AM
    Trapper6speed
    Stock
    Ya lucky it came with the sencor.
