Oxygen Sensor Cleaning?
Discussion in '1st Gen. Tacomas (1995-2004)' started by derekp, Jan 19, 2010.
  1. Jan 19, 2010 at 7:52 AM
    derekp
    derekp [OP] giddy up!
    Derek
    Grand Forks, ND
    2001 X-Cab 4x4 TRD V6 5Spd
    Deck plate, Flowmaster Delta-Flow 40 series, 265/75-16 Wrangler TDs, more to come...
    Can you clean the O2 sensor on the 1G Tacoma or do they have to be replaced? They run around $80 for the downstream sensor and more the upstream sensor. Looking at around $200 for both I was hoping to save some money by cleaning them if possible. I have about 122k miles and have been doing a few weekend maintenance tasks on the truck. Tranny/axle fluid change is in coming soon. Thanks for the input.
  2. Jan 19, 2010 at 7:53 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    you can clean it :)
  3. Jan 19, 2010 at 7:53 AM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    COOL! how? spit?
  4. Jan 19, 2010 at 7:54 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    I cleaned mine with carb cleaner
  5. Jan 19, 2010 at 7:56 AM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    neat, I'll do mine today. thanks
  6. Jan 19, 2010 at 7:59 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
  7. Jan 19, 2010 at 8:10 AM
    derekp
    Derek
    Grand Forks, ND
    I'll give this a try. I haven't had a CEL yet but my mileage hasn't been as good as my 2000 V6 TRD. Maybe this will bump it back up a bit. Did you just spray it down real well or brush it with anything also?
  8. Jan 19, 2010 at 8:18 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    Nope just hosed it down :)
    All the dirt and shit will just run off...i'm sure you can gently wipe it though :notsure:
  9. Jan 19, 2010 at 10:36 AM
    97Blk_one
    97Blk_one Well-Known Member
    Memfrica
    not so low
    A whole lot,But not satify
    How do you take that thang off? which one ? Bank 1 Sensor 1 or Bank 1 Sensor 2? please help !
  10. Jan 19, 2010 at 3:50 PM
    derekp
    Derek
    Grand Forks, ND
    There are two; one before the cat, one after. Each should be held on by two nuts. Be careful though. I busted the bolt on one on my old 2000 Tacoma and had to use a hose clamp to keep the sensor back in place.
  11. Jun 20, 2012 at 9:17 PM
    pippen
    pippen that was'nt a vitamin!!
    Pippen
    Eastern NC
    04 PreRunner Ext.
    Well I know this is a old thread, but Im removing my o2 sensor now to try to clean it after a guy at auto store said to try 108 octane and premium to see if that helps, he swore it did on his minivan :) Did not work really so I'm letting the sensor end soak in some MEK. Will let you guys and gals know how it worked tomorrow. I see alot of people on the internet talk about brushing them and such, from my understanding the actual sensor is protected by the outer shield. As why I chose MEK, well my dad thought it would be a good start, anything that dissolves carbon deposits seems like a good idea too.
  12. Jun 20, 2012 at 11:45 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The sensor...is actually a 'heater' that heats up.... cleaning may work for a period of time, the sensor can and will fail if the heater isn't working properly.
    http://en.wikipedia.org/wiki/Oxygen_sensor
    It actually mentions this inside my old 96 tacoma owners manual.
  13. Jun 21, 2012 at 4:57 PM
    pippen
    Pippen
    Eastern NC
    04 PreRunner Ext.
    Well the soak in MEK did not work....the truck ran fairly rough at low rpm, compared to perfect running before soak :( I'll just buy a new one found a extremely cheap online vendor :D
