Ozark Trail 73-Quart & 26-Quart High Performance Roto-Molded Coolers - "Real World" Test
Discussion in 'Product Reviews' started by dan0mite, May 23, 2016.
  1. May 28, 2016 at 6:48 AM
    #121
    1rooster
    1rooster TACOMA31750
    Georgia
    2007 Tundra crewmax
    5100's ALL WAY AROUND, 885X COILS, DRIVER SIDE LEAN SPACER, ICON PROGRESSIVE AAL W/O OVERLOAD, 265/75/16 KENDA KLEVER M/T. 1 1/4 SPIDERTRAC WHEEL SPACERS, GEN 1 TRD COLD AIR INTAKE, STOCK MUFFLER WITH CHOPPED TURNDOWN, 5% TINT OVER FACTORY, DEBADGED, TOYOTA RUBBER BED MAT, WEATHERTECH MATS,UWS TOOLBOX, UNDERCOVER SE, LOCKER MOD, REAR BUMPER, PIONEER DOUBLE DIN WITH PARKING BREAK OVER RIDE, CUSTOM OIL CATCH CAN, FULL LED INTERIOR, ARB BUMPER REPLACEMENT. COVERKING SEAT COVERS. MORIMOTO H1 MINI COVERSION WITH MINI GATLIN GUN SHROUDS AND 5000K MORIMOTO BULBS. TRAILER PLUG RELOCTED TO BUMPER. 20 INCH LED LIGHTBAR MOUNTED BEHIND CUSTOM PAINTED GRILL. STUBBY ATNENNA
    If that was 73 degree id hate to see what it would do in 100+ degree weather. How well made do the latches seem?
  2. May 28, 2016 at 8:17 AM
    #122
    dan0mite
    dan0mite [OP] #NOTNORM
    Dan
    SC
    d00kie
    Check The Build Thread
    Sorry for the misunderstanding as I fat-fingered that post but have since edited it. I meant that the 73qt cooler was the one that did it in direct sunlight; however, the weather was in the mid to high 80's.
    The latches seem sturdy enough as they are what I've been pulling on to open the lid against a vacuum. I just don't know if they were barely snug from manufacturing and were able to work loose under normal use or not. Either way, I've snugged them down nice and tight so over the next few days I'll keep an eye on them to see if they remain snug.
  3. May 28, 2016 at 8:26 AM
    #123
    dan0mite
    Dan
    SC
    d00kie
    Here are pics of what I was referring to regrading the top of the cooler. Just took these right now and current weather shows 81 degrees out now.
    Again, it goes back down to normal after being in the shade.
    I hope this isn't something that affects all the large coolers and if it does, the 5 year warranty will get exercised quite a bit I feel.
    After my test is done, if there is another 73 in stock close by I will probably take this one back and exchange it.
  4. May 28, 2016 at 8:28 AM
    #124
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    Nice thread! I think competition in the high end cooler market is a great thing. My Roadie yeti has been relegated to being locked in the bed of my truck for beer duty, and it works out great. We'll see how well it holds up after a summer's worth of heat!
    dan0mite[OP] likes this.
  5. May 28, 2016 at 8:29 AM
    #125
    Polymerhead
    Missouri
    That is concerning. Makes me think you have a void in there. The Yetis are filled with foam, so I don't think that would be an issue with them. I'd take it back and switch it out for sure. Might just be they didn't get your lid completely filled.
  6. May 28, 2016 at 8:38 AM
    #126
    dan0mite
    Dan
    SC
    d00kie
    My thoughts as well but I'll wait until the test is over. I'll also check for more of the same on the other sides of the cooler. Hopefully it's an isolated issue with my cooler or just the batch mine was a part of.
  7. May 28, 2016 at 10:34 AM
    #127
    1rooster
    Georgia
    2007 Tundra crewmax
    Oh wow. A lot of guys I work with have k2 and yetis that sit in the back of their truck 24/7 and Iv never seen such on them. It appears the inside foam did not expand to the full potential. Even though it seems to not have effected the cooling abilities, it would still concern me.
    dan0mite[QUOTED][OP] likes this.
  8. May 28, 2016 at 10:52 AM
    #128
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Wonder if there is a way for us to test for this at the store, before purchase?
  9. May 28, 2016 at 10:59 AM
    #129
    1rooster
    Georgia
    2007 Tundra crewmax
    Go to the hair dryer isle and take one for a test drive!
  10. May 28, 2016 at 11:05 AM
    #130
    1rooster
    Georgia
    2007 Tundra crewmax
    In all honesty I reckon you could go to the garden center and hang out there in the sunlight for some time.
  11. May 28, 2016 at 11:05 AM
    #131
    dan0mite
    Dan
    SC
    d00kie
    When I take this one back to exchange, I will let Walmart know it's defective so they don't try to put it back on the shelf. I'll also look closely at the new one I exchange it for now that I know what to look for.
    Also, once the cooler cools off and the plastic has a chance to "normalize", I'll see if it goes back down tight or if there's still any play. Looking at it now, it's back down but there's still a little bit of a rise in it currently.
  12. May 28, 2016 at 12:04 PM
    #132
    Polymerhead
    Missouri
    I've seen tests with the laser-type "instant read" thermometers where you would fill it with ice, wait an hour or so and then scan all over it with the thermometer. Cold spots on the outside surface would indicate possible voids in the insulation.
    No help to you in picking a replacement though. Can you thump on it like a watermelon and hear any difference in that spot?
  13. May 28, 2016 at 2:34 PM
    #133
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    I'd wager (of course I have no idea if true) that all the insulation is in tack, it appears to me that the "shell" of the lid is of course airtight and the heat is just ballooning it up with with the trapped air inside.
    dan0mite[OP] and RogueTRD like this.
  14. May 28, 2016 at 4:37 PM
    #134
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    well.. my real world test failed.
    Filled with Ice on Friday noon..
    Was good until Saturday afternoon:
  15. May 28, 2016 at 4:40 PM
    #135
    tomwil
    East Coast USA
    2014 Reg Cab 4x4
    Latch handle failed? On both?
  16. May 28, 2016 at 4:48 PM
    #136
    ramonortiz55
    Ramon
    Texas
    stock
    latch handle failure
  17. May 28, 2016 at 4:56 PM
    #137
    Boogyman
    Boogyman Well-Known Member
    Phoenix
    Corpus Christi, TX
    2022 Lunar Rock Trail Edition
    Reading this thread like:
    AugustaTaco, SC2SC, Acerwin and 5 others like this.
  18. May 28, 2016 at 4:59 PM
    #138
    dan0mite
    Dan
    SC
    d00kie
    The latch handles on both of mine are still good and I've been pulling on them every day. Even to open the 73 top against a vacuum.
    What happened to @ramonortiz55's cooler is definitely disconcerting. What circumstances led to the failure Ramon?
  19. May 28, 2016 at 5:01 PM
    #139
    Boogyman
    Phoenix
    Corpus Christi, TX
    I would drill a hole in the under side of the lid and fill the whole lid with expanding foam if they're all that way
  20. May 28, 2016 at 5:04 PM
    #140
    Polymerhead
    Missouri
    I hear that. I have:
    Roadie 20
    Tundra 45
    Tundra 65
    Three 20 oz ramblers
    One 30 oz rambler
    One 10 oz lowball
    One can cooler
    But the $90 growlers are just crossing the line...
