OZBoost turbo group buy 2TR-FE and 3RZ
Discussion in 'Group Buys' started by SUMMIT556, Jun 8, 2015.
  1. Jan 11, 2016 at 1:42 PM
    #81
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  2. Jan 12, 2016 at 9:49 PM
    #82
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
  3. Jan 13, 2016 at 4:56 AM
    #83
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Back on the topic of a vacuum leak. Looking at your breather on your valve cover, and that you say the pcv hose at the back of the valve cover is attached to the intake manifold, that means your engine still have a very large vacuum leak according to the MAF sensor.
    When compared to these pictures.
    Your engine is sucking in unmetered air after the MAF sensor, through the filter on the valve cover.
    chutson99 likes this.
  4. Jan 14, 2016 at 2:12 AM
    #84
    TacoTaco15
    TacoTaco15 Well-Known Member
    Jake
    VA
    2015 MGM DCSB PreRunner 2.7
  5. Jan 14, 2016 at 9:22 AM
    #85
    weldo
    weldo Well-Known Member
    Pittsburgh, pa
    2014 base ac 2.7 5-speed 4x4
    Here's some diagrams that outline the PCV circuit. I used these for reference when I added a catch can. Maybe it'll help.
    I am also looking for info on adding a catch can to a 2tr. I found these diagrams on TW somewhere...
    So in the second image it seems pretty clear that the PCV (or what Toyota calls the "Ventilation Valve") is located on the back left of the valve cover as you look at the front of the engine.
    It follows from A through a rubber elbow, then through a metal pipe to B at another rubber elbow, then into the intake manifold. Pretty straight forward to add your can in the loop somewhere.
    My main question is the small pipe with outlets labeled C and D. Are these hooked to the PCV circuit or are they independent? I'm guessing that C and D make a tiny closed loop unto themselves and are not connected in any way to the PCV circuit. Anyone know for sure?
  6. Jan 14, 2016 at 10:15 AM
    #86
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That is a good question about "C"&"D". Take a look back there and snap a picture or two. It will be pretty clear where they are routed to.
    You are correct about the catch can attachment. Anywhere in between "A"&"B".
  7. Jan 15, 2016 at 4:59 AM
    #87
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    @weldo , C & D are independant of the PCV hard line. Those are ports for coolant to circulate next to the pcv line, to aid in heating it up. Verified when I went to Toyota yesterday and checked out multiple diagrams. :thumbsup:
  8. Jan 15, 2016 at 2:53 PM
    #88
    weldo
    Pittsburgh, pa
    cool man, thanks!
  9. Jan 15, 2016 at 3:06 PM
    #89
    weldo
    Pittsburgh, pa
    Not to thread jack but it looks like this is a crank case vent leading into the air intake.
    I didn't even notice this when I added my catch can into the PCV circuit. So if this vent is still blowing oily air into the intake, does that make the catch can kind of pointless? I know the can works, as it collects oil over time, but the point is to stop all the oily mist, not just some of it. Should I somehow plumb this over to the catch can with a T fitting or something? I don't think a breather will pass emission inspection around here.
    Again I don't mean to thread jack, but I figure while we're on a similar topic...
  10. Jan 15, 2016 at 5:23 PM
    #90
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That hose is the fresh air inlet into the valve cover. Where the circulation starts. The intake manifold sucks the air from there, into the valve cover, out of the valve cover, into itself, then onto engine.
    Don't change or remove that. Unless upgrading with silicone.
    For the turbo setup, it can be removed, but the inlet of the intake manifold would have to be capped. So as not to suck in unmetered air. Then both the inlet and outlet would need to be routed into the catch can.
    Or the filter could be added to the outlet of the valve cover, and the inlet of the valve cover would then be routed to the inlet of the turbo. Right behind the filter. Effectively reversing the flow through the valve cover, and still sucking it into the engine.
  11. Jan 15, 2016 at 5:36 PM
    #91
    weldo
    Pittsburgh, pa
    I think I see what you mean, but wouldn't the air rushing past that hose serve to suck air out of the valvecover? Or is it perhaps that when the PCV opens, the air is drawn from the intake tube (before the throttle body) by the suction in the intake manifold runner (where the PCV is connected, after the throttle body)?
  12. Jan 15, 2016 at 5:51 PM
    #92
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Maybe nothing to do with it but I wonder if a pcv check valve would make a difference; it definitely helps on the Buick GN. [​IMG] Photo courtesy of Kirban Performance
    Chris D. likes this.
  13. Jan 15, 2016 at 8:25 PM
    #93
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    No. Intake manifold, post throttle body, is the source of the suction.
  14. Jan 15, 2016 at 8:45 PM
    #94
    weldo
    Pittsburgh, pa
    Got it! Thanks brother!
  15. Jan 15, 2016 at 9:57 PM
    #95
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  16. Mar 15, 2016 at 6:16 PM
    #96
    godwinaustin
    godwinaustin Well-Known Member
    Jon
    WYO
    2004 4x4 5VZ + 1982 4x4
    bump! a turbo 2TR sounds AWESOME. I want to make this mod happen down the line. Turbo or new bumper hmmm
  17. May 16, 2016 at 3:23 PM
    #97
    icur
    icur Member
    2007 Desert Mica Tacoma Regular Cab 4x2
    BakFlip CS-F1 AMPED HD
    Dodgymechanic
    which size intercooler you used?
    where you drill for oil return?
  18. May 18, 2016 at 11:58 AM
    #98
    KirkRio
    KirkRio taco taco burrito burrito
    Kirk
    Wesley Chapel, FL
    2005 Tacoma SR5 PreRunner
    Drill the upper oil pan, there is a flat spot behind the engine mount which worked perfect.
    Highly recommend dropping the lower oil pan before doing this.
  19. May 18, 2016 at 2:33 PM
    #99
    icur
    icur Member
    1/2-14 npt okay ?
  20. May 18, 2016 at 3:11 PM
    #100
    KirkRio
    Kirk
    Wesley Chapel, FL
    Yessir, or whatever fitting you decide to go with but the supplied 45 degree 1/2" npt to -10an works good.
