OZBoost turbo group buy 2TR-FE and 3RZ
Discussion in 'Group Buys' started by SUMMIT556, Jun 8, 2015.
  1. Jun 24, 2016 at 6:19 PM
    #121
    weldo
    weldo Well-Known Member
    Pittsburgh, pa
    2014 base ac 2.7 5-speed 4x4
    Nice! There's a guy on the for sale forum with a +3.5 Total Chaos kit for sale. Everything but the axle shafts I think.
  2. Jun 24, 2016 at 6:26 PM
    #122
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Looks like he is a 5 lug. Nice turbo long travel prerunner.
  3. Jun 24, 2016 at 6:26 PM
    #123
    Desertrunner33
    Desertrunner33 Active Member
    Trenton
    2005 white 2tr-fe actual prerunner
    There isn't much that's stock anymore
    Oh I'll check it out. This is 2wd so I shouldn't need axle shafts anyways. I'll have to check to see if that one is 5 lug
  4. Jun 24, 2016 at 6:31 PM
    #124
    MadTaco461
    CA
    Kinda stock
    That is a 6 lug kit though. I'd check out @KirkRio build. He switched out a good amount of parts on the OZ kit to more reliable parts.
  5. Jun 24, 2016 at 6:35 PM
    #125
    Desertrunner33
    Trenton
    Yeah I've been reading a lot of his stuff. I plan to use this as a starting kit and then build off it and eventually be running a little higher than the 5-7 psi boost it is set up for. I'm curious how much he had to bend his AC lines because he mentioned that a few times. I'll definitely get a new fpr per his recommendation and probably that ecu piggyback they mentioned earlier as well
    MadTaco461 likes this.
  6. Jun 24, 2016 at 6:40 PM
    #126
    MadTaco461
    CA
    Kinda stock
    Awesome. Make a build thread when things start coming together.
  7. Jun 24, 2016 at 6:42 PM
    #127
    Desertrunner33
    Trenton
    Ok will do. I'll try to put up some pics of everything that the kit came with and maybe some videos of the issues that seem to be common when installing the kit.
  8. Jun 24, 2016 at 6:44 PM
    #128
    MadTaco461
    CA
    Kinda stock
  9. Jun 24, 2016 at 7:40 PM
    #129
    imom
    imom Well-Known Member
    CAL
    2014 Regular Cab
    Are you MadTaco's brother? :) Another prerunner that will be bad ass when done. Looking forward to how the kit works out for you. What state are you in? Cali is quite hard to get any kit to run without smog issues later
  10. Jun 24, 2016 at 8:25 PM
    #130
    Desertrunner33
    Trenton
    I'm new to this forum so I will have to get o know everyone haha but yes I am from CA. I just got my new smog last month (can't believe I passed) so I have 2 years til I have to worry about it. I may be able to pass smog with a turbo but if not my family has a house in Lake Havasu, AZ so I will register there where there is no smog
  11. Jun 24, 2016 at 10:51 PM
    #131
    imom
    CAL
    2014 Regular Cab
    AZ has no smog requirement? That's a modder's dream. For sure you won't pass visual inspection.... even with a header would be a problem...I'll need to find out end of this year I think.
  12. Jun 24, 2016 at 10:53 PM
    #132
    Desertrunner33
    Trenton
    Certain parts of AZ do and others don't. I'm pretty sure only Phoenix and Tucson areas require it. I know you don't need it in Lake Havasu. Kind of odd I know
  13. Jun 25, 2016 at 3:49 AM
    #133
    weldo
    Pittsburgh, pa
    Sometimes it varies by county. Here in PA Allegheny County requires it. My brother lives in the next county over in Uniontown (Fayette County) and they do not require any emissions testing.
    @Desertrunner33 Where did you end up ordering the kit? Is buying just the exhaust manifold an option?
  14. Jun 25, 2016 at 7:00 AM
    #134
    Desertrunner33
    Trenton
    I got it from ebay. The ozboost site says worldwide shipping but then when you go to check out it was saying sorry we don't ship to the United states so then I went to ebay and couldn't add it to my cart for some reason so I called their tech support line and they helped. I guess because it's an Australian item you can't add it to an American shopping cart so I had to go to ebay.com.au and then do it and then it worked fine.
    As far as buying them separately I don't know if it's a possibility but I saw a lot of other people talking about it
  15. Jun 26, 2016 at 7:43 PM
    #135
    johnnys219
    johnnys219 big dreams, little money
    johnny
    new jersey
    2015 dclb trd sport
    3 inch bilstein lift. 4runner brake upgrade. offroad bumper. full on board air and electronics
    Does this turbo only use one side of the exhaust. Shouldn't you combine both exhaust manifolds befor sending into turbo.
  16. Jun 26, 2016 at 7:49 PM
    #136
    weldo
    Pittsburgh, pa
    this kit is for the 4 cylinder. It only has one manifold.
  17. Jun 26, 2016 at 8:11 PM
    #137
    johnnys219
    johnny
    new jersey
    2015 dclb trd sport
    Well now that makes more sense
  18. Jun 26, 2016 at 10:01 PM
    #138
    Desertrunner33
    Trenton
    Just so you know most turbo set ups only use one side of the engine to spin the turbo (v8, v6). Really the only time you use both sides would be in a twin turbo set up. One for each side obviously. Someone correct me if I'm wrong
  19. Jun 27, 2016 at 5:52 AM
    #139
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    2JZ-GTE, RB26DETT. Audi S7 4.0 TSFI V8 TwinTurbo, ( with both turbos in the valley) ;)
  20. Jul 1, 2016 at 11:33 PM
    #140
    Desertrunner33
    Trenton
    Alright my turbo kit is supposed to be delivered on Wednesday. If there is any interest I'm thinking about taking a video of the unboxing and showing you all what came with the kit and such. If a couple speak up I'll put it on YouTube
