Oznium mount
Discussion in 'Lighting' started by MDBigRed, Aug 28, 2009.
  1. Aug 28, 2009 at 3:35 PM
    MDBigRed
    MDBigRed [OP] Well-Known Member
    Potomac, MD
    '08 TRD Sport 4x4
    Uniden PC78Elite CB, 4' Firestiks, KC reverse/work lights, Mudflaps removed, Gorilla wheel locks, TRD box air intake, MBRP XP series dual exhaust, Wet Okole seat covers, 20% front tints, Pacer tailgate light bar, Uniden Bear Cat PA external speaker, 4.5" RCD Lift w/ extended ICON coilovers, door sill LED running lights, LED alarm scanner light, Scangauge II, Blendmount, Diff breather mod, Whelen hideaway 90watt strobes, Piaa Xtreme white bulbs, VIAIR onboard air, Allpro T-case sheild, TC LCA Skids, Stubbswelding HD-SKO Sliders, Weathertech floor mats, TC UCA's, Allpro SS brakelines, rear ARB locker, 4.56 Yukon gears, BlueSea fuse block, bed rail light bar, Shrockworks bumper, Smittybuilt XRC8 Comp winch, IPF 900's, Piaa 510's, Tekonsha brake controller, Air horn, Pop 'n lock, Alcan Spring leaf packs, JVC KD-AHD 69 head unit, 12voltguy winch controller, Safari Snorkel
    I just bought 4 oznium bright white marine LED puck lights to use as rock lights (1 at each wheel). I'm planning on simply saudering the lines and running to battery power source and led switch inside the truck. WHERE CAN I FIND SELF TAPPING SCREWS SMALL ENOUGH FOR THE HOLES?? I went to my local hardware store and couldn't find any screws small enough. Epoxy won't work either. anyone have suggestions for me?? I'll probably add some more lights under the door sills in the future and in the engine bay
  2. Aug 28, 2009 at 3:37 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    Port Hueneme
    15 Ram EcoDiesel
    try radio shack maybe? they tend to have random crap
  3. Aug 28, 2009 at 3:50 PM
    Pster
    Pster Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    Ouch...try "soldering" instead of "saudering". We all misspell, including me.....but I love our English language too much to ignore........no disrespect intended...Good Luck with the lighting!!! :):):)
  4. Aug 28, 2009 at 8:15 PM
    MDBigRed
    Potomac, MD
    '08 TRD Sport 4x4
    haha it's all good. you interpreted correctly! :D
