P-0031 Code Solution in 3.4L Tacoma
Discussion in 'New Members' started by FED Driver, Sep 27, 2018.
  1. Sep 27, 2018 at 6:42 PM
    FED Driver
    FED Driver [OP] New Member
    Dave
    2004 Red Tacoma TRD
    Stock 3.4L
    Hi - I'm Dave and live in Saugus, CA, driving a 2004 Tacoma extended cab 2-wd with 3.4L engine. Purchased this truck new in So. California, it now has 114,750 miles on the odometer.
    Three weeks ago, the CEL threw a P-0031 code, indicating a bad up-stream A/F Sensor. The bad sensor Toyota p/n 89467-35060 was removed. The OEM replacement starts at $196 on Amazon, $280 at the dealer, but many vendors on Amazon, Ebay, auto parts stores and posts state that the Denso p/n 234-9001 is a valid replacement for the OEM Toyota part. NOT so.....
    I purchased the Denso part and installed it. The truck CEL extinguished, but the engine surged and pulsated at all speeds. Not good. A replacement Denso unit was sent, installed, and with the same results. Not really driveable, but the CEL lite was OUT.
    Last week I bit the bullet and ordered the OEM Toyota part number 89467-35060 for almost $200. In ten minutes it was installed and the truck runs like new.
    Hope this helps someone in a similar predicament.
    irayfz6 likes this.
  2. Sep 27, 2018 at 7:11 PM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    Welcome!
    Glad you got it figured out!
  3. Sep 28, 2018 at 4:42 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
