P vs LT rated tires?
Discussion in 'Wheels & Tires' started by freesample, Feb 19, 2009.
P or LT rated tires.
  1. P
    243 vote(s)
    43.9%
  2. LT
    311 vote(s)
    56.1%
  1. Mar 31, 2009 at 7:37 PM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    Well, my truck came with P-rated 265/65/17. I only found (1) LT rated tire in that size and it sucked. I went to a 255/75/17.
  2. Dec 4, 2009 at 6:48 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    p rated are Passenger and LT is Light truck tires. LTs are heavier but are tougher. Ps arent available in real aggressive tread and arent meant to leave the pavement. LTs have stiffer sidewalls and can old more weight and are made of tougher materials, can be aired down and resist punctures or sidewall damage.
    LarryC213 likes this.
  3. Dec 5, 2009 at 9:07 AM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    HP60/14 bolt, Atlas 5.0.
    Load range "E"s baby!
  4. Dec 5, 2009 at 9:28 AM
    dhurley
    dhurley Well-Known Member
    Doug
    Colorado Springs, CO
    04 Double Cab TRD SR5 V6
    TRD, Snugtop Super-Sport, bedliner, receiver hitch, alarm mod, deck plate mod, AFE Pro-Dry S, Saddleman camo seat covers, TW decal, grey wire mod w/switch, DRL, LED cupholder mod, Dynomax Super Turbo, aux back-up lights, Devil Horns by Andres, "blue plug" mod for 2LO, shorty antenna, Pro Comp fog & driving lights, receiver shackle, 15% tint front windows, stainless nerf bars, Ultra Gauge, diff breather mod
    You can get some P rated tires in an Extra Load, they will handle a little more weight than the normal P rated tires. Also if you're looking for treadlife warranty, sometimes with the same size/brand tire, the P rated have 10k more miles on the warranty than the LT. You just have to decide for yourself what the important features are to you.
  5. Dec 6, 2009 at 5:12 AM
    07speedwayblue
    07speedwayblue Well-Known Member
    michael
    nineveh, Indiana
    07tacoma sport 4x4 doublecab
    Jason Rage lid, husky floorliners, Procomp 6" stage 1 lift , bilstein 5100 upfront, 33x12.50r17 MT ATZ tires MT 17x9 Classic Locks,stainless steel brake lines,N-Fab ss nerf bars,smittybuilt grille saver, Amp bed extender,Mbrp cool dual t409 exhaust. KCHiLites Daylighter Driving Lights 6", Pioneer AVH-P4300DVD, HD Tunner, Rear Camera, Focal K2 Power 6.5" Component Speakers Front/Back, Infinity Kappa Four and Kappa One Amps, Infinity Kappa 10" DVC Subs,PowerStop Drilled/Slotted Rotors ,PowerStop Heavy Duty Towing Brake Pads, Blue Painted calipers.
  6. Dec 6, 2009 at 3:01 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    A lot of time its an extra ply under the tread , a p-metric will often go to 36 max for this reason and a lt will go to 51 psi. Its harsh ride for 1 more ply or smoother ride for 1 less ply
  7. Apr 12, 2010 at 8:56 AM
    Tillers_Rule
    Tillers_Rule ......................
    Jeff
    San Diego
    4x4 Sport, debadged
    Icon coil overs up front, Total Chaos UCA, Icon remote reservoir in the back with Deaver 11 pack leafs. Sunroof, Hella 500's behind grill.
    My truck came with P's and the tread was toast at 25K miles. Threw on some LT's and still had half the tread at 25K (replaced them with a larger size). That wear could be dependent on a number of factors but for the purpose of this thread I'll blame it on the rating:)
  8. Apr 13, 2010 at 8:25 AM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    ^^^what was the difference in tread depth between the two? The rugged trails are pmetric but only have 10/32's td while the same size bfg all terrain in the Lt has 16/32's. So of course the all terrain is gonna last longer.
  9. Apr 13, 2010 at 8:29 AM
    TacoSupreem
    Hayden
    Kentucky
    The bfg all terrains in Lt 265/70r16 are 12lbs heavier per tire than the rugged trails that come stock. Will that extra weight be very noticeable? I wonder how badly it'll affect my mpg and braking power?
  10. Apr 22, 2010 at 11:39 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    E rated LT tires. 265/75R-16 Yokohama Geolandar AT-S
  11. Apr 24, 2010 at 6:20 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    On the trail, P-metric tires are referred to as 'maypops'. I have LTs.
  12. Apr 27, 2010 at 7:43 PM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    Cooper discoverer STT (LT 285/70/17 load range D)
  13. Feb 15, 2011 at 6:39 PM
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    I have had E rated tires in the past on my old truck and that is what I will replace my shitty factory tires with. I don't care how they ride, it's a truck. I care about shredding them when I'm out hunting. I've never had a flat with E rated tires.
  14. Feb 16, 2011 at 12:07 PM
    RLDTACO
    RLDTACO Well-Known Member
    Bob
    Houston Tx.
    2010 DCLB PreRunner SR5
    Debadged,Tailgate theft mod,Extra D-rings,OEM bed mat,TRD exhaust, 5100 Billys@ 4 corners set@ 0 with Eibach springs, rear TSB springs.N-Fab tube Steps. TRD FJ SE wheels and Michelin LTX A/T 2's
    Michelin LTX AT/2, LT 265/75/16, ride is more firm than stock dunlops, but hey Tacoma=truck. :D
  15. Feb 16, 2011 at 12:55 PM
    #35
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    LT C rated.
  16. Feb 17, 2011 at 6:14 AM
    #36
    90YotaPU
    90YotaPU The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    P265/75R16 Hankook Dynapro ATM's. Great tire and have had them offroad three times since I've gotten them. They hold up well and don't have all the extra weight to bog down the 4 cylinder.
  17. Mar 16, 2011 at 11:36 PM
    #37
    dbronzo
    dbronzo Protected by Armor Tech Offroad
    Dennis
    Fayetteville, NC
    08 TRD Sport 4x4 w/ some Mods
    King Coilovers, LR UCA's, All Pro Sliders, ATO Full Skids, Pioneer AVH-P4300, 4.56 Gears, Front and Rear ARB Air Lockers, ATO Full Wrap High Clearance Bumper w/ Tire Carrier, ATO Hybrid Bumper, Smittybuilt XRC 8, Lightforce 240 Blitz, Rock Lights
    I have Ps now but am going to LTs
  18. Mar 16, 2011 at 11:39 PM
    #38
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    265/70/17 LT E rated Hankook Dynapro MT's
    I like em .
  19. Apr 23, 2011 at 8:24 AM
    #39
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    P-rated Hankook dynapros are about $35 cheaper per tire than the LT tires, and the jump was from P-rated to E-load, at least at my tire place. If there were C-rated or D-rated Hankooks I might have gone LT but I went with the P. We don't have trails around here, and I mainly wanted the tire for looks, help with highway snow in the winter and the occassional washed out gravel road or flooded low-crossing when hunting. The Hankooks take up to 44 lbs of pressure so I suppose they're a litte tougher than the average P-rated tire anyway.
  20. Apr 23, 2011 at 8:55 AM
    #40
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I replaced the stock rugged trails at 15,000 miles with e rated bfg a/t's 265/75/16 and couldn't be happier. The truck handles alot better around corners and the "bone jarring" I've read about is a non issue. The ride is a bit rougher but not that noticable. I've gone through a few sets of these tires over the years and have never had a flat... In the short time I had the stock p-rated tires I had 2 flats.
