P vs LT rated tires
Discussion in 'Wheels & Tires' started by PistolPetey, Jan 24, 2017.
  1. Jan 24, 2017 at 4:34 AM
    PistolPetey
    PistolPetey [OP] Well-Known Member
    Peter
    Long Island, NY
    07 TRD Tacoma DB cab LB
    I just purchased new rims for my Taco and now its time to buy tires. I've been shopping around a lot and I think I'm going to go with the Hankook Dynapro ATMs. I drive mostly on pavement back and forth to work and occasionally go off road (jobsites, beaches, just about any trail I can find). I occasionally load my truck bed up with lumber/tools for work but its usually empty. Do I need a LT rated tire or will I be ok with P rated?(265/75R16) Also open to suggestion for a different tire if anyone has a suggestion.
  2. Jan 24, 2017 at 4:36 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    For what you describe - "P" will be all you need.
    nv529 likes this.
  3. Jan 24, 2017 at 5:18 AM
    karmatp
    karmatp Well-Known Member
    Trevor
    Chandler, AZ
    2016 4x4 4Runner
    Load range C at max for all Tacoma's. Load range E is way overkill and way to heavy for our trucks.
    mustangwilly likes this.
  4. Jan 24, 2017 at 5:26 AM
    Fifthwind
    Fifthwind Master of None
    Murph
    Lehigh Valley, PA
    Scully
    Barcelona Red 09 DCOR- Icon 2.5" ECOs w/CDC - 14" 700lb, ICON 2.0 RR Ext rears, AP EXPO pack, Diff Wedge, Diff and Skid Drop, Discoverer S/T 255/85/16, Ride-Rite Bags w/ Daystars, ARB Bull/winch Bumper, Warn 8k, ARB CMK12, Budbuilt skids, BAMF bolt on sliders BAMF diff diaper, bedlights, hoodlights, BAMF CB, etc.
    ^This.
    I run a set of P rated mud and snow for my street set, and D rated for off roading rocky and rooty trails. The difference is in the sidewalls.
    You do not want to lower air pressure in P rated at all, if you do air down, go with Load range C.
  5. Jan 24, 2017 at 8:31 AM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
  6. Jan 24, 2017 at 8:37 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    I'm running LT 265/75 16 Toyo Open Country Mud Terrains and no problems
  7. Jan 25, 2017 at 7:57 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    The GVWR for the Tacoma won't exceed the rating of standard load (P) tires, so no need for LT. I'm not sure if it's consistent across all brands, but I have noticed LT tires having a slightly harder tread compound which results in longer tread life.
  8. Jan 25, 2017 at 10:13 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    My 265/75 16 Toyo open country mt tires have a max load of 3415lbs and even though max press is 80psi I've got them at 65psi
    My 2002 Double cab has a curb weight of 3480lbs and max load rating of 5k lbs
  9. Jan 13, 2018 at 10:33 PM
    MCM78LC
    MCM78LC Well-Known Member
    Saint Paul, MN
    2021 Toyota Land Cruiser
    What about consideration of LT stiffer sidewall for towing RV? I am currently running Michelin P265-75-16 on my TX Pro dbl cab towing a 1 axle Airstream and there's too much wiggle for my taste (flex in sidewall not sway). Considering going to LT's. Wondering if they'll be too stiff on a daily driver. Opinions welcome. Thanks!
