P0018 I dont know what to do!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by deaner98, Jul 21, 2023.
  1. Jul 21, 2023 at 11:40 AM
    deaner98
    deaner98 [OP] New Member
    2012 Tacoma
    Hello, I am looking for some advise. I have a 2012 Tacoma TRD Sport, with 230,000 KM. I have recently got this code for the camshaft position sensor. The engine is running and sounding fine. The code has come on and off as well. Typically will come off after an oil change. The last time the code came on, the engine ran ruff for about 3 seconds, almost like a weird vibration, then back to normal. I have talked to a few different shops and have been told a bunch of different things. Toyota dealership is telling me the timing chain needs to be replaced and quoted me almost 6k CAD to get it fixed. They also said we can try getting the sensor replaced first, but probably wont fix my issue. They Quoted 1k CAD to replace the sensor.
    Someone also recommended draining half my oil and running some ATF to try to clean the sensor as they can apparently get pretty dirty.
    I dont know much about engines, so I am hoping someone has had a similar issue and knows a fix.
    tcjacado likes this.
  2. Jul 21, 2023 at 11:57 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Dm93 and tcjacado like this.
  3. Jul 21, 2023 at 12:11 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    do not put ATF in your oil please
    TRDSport10 and tcjacado like this.
  4. Jul 21, 2023 at 12:31 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Do not add ATF to your oil!
    Lots of good info in my thread. @TnShooter linked above :thumbsup: Is P0018 the only code?
    It is possible the VVT screen(s) are plugged if oil changes have been neglected. You say it gets better after an oil change.. Easy to check. If not that, probably a solenoid. P0018 is the drivers side. I think the VVT screen is a little more tricky to get to on that side (behind the AC) but I am not 100% sure on that, I only had to deal with the passenger side.
    As a side note, $1k is highway robbery for replacing the camshaft position sensor
    TnShooter, Dm93 and Geeves77 like this.
  5. Jul 21, 2023 at 12:34 PM
    tacobp
    tacobp Well-Known Member
    Bob
    North Carolina
    09 Tacoma, 2.7 automatic
    Installed a Pop n Lock,,That's it !..Bone stock
    Wow ! 6 grand to replace a timing chain. I have no idea of the work involved to do that...I just recall replacing timing chains 40 years ago in old school cars....Just about the cost of the chain is all ! Well...that was then..
    Crosis and Geeves77 like this.
  6. Jul 21, 2023 at 1:38 PM
    Geeves77
    Mark
    Northeast
    2011 Tacoma DCSB
    not hard just time-consuming, as that old commercial goes if you got the time, we got the beer, Miller beer
  7. Jul 21, 2023 at 4:18 PM
    Waasheem
    Waasheem
    2007 xrunner
    I worked with someone who did all atf & destroyed his engine. I’ve done it to my air compressor but I just added a tiny amount, less than 1/16 quart, ran it for a couple minutes then drained it.
  8. Sep 12, 2023 at 5:34 PM
    deaner98
    2012 Tacoma
    I have an update. It needed a timing chain and gears, 7k CDN later I have my truck back. Now I am concerned about the sound, only while accelerating i am hearing a ticking. like a zip tie hitting a fan almost, When a truck is at idle sounds completely normal.
  9. Sep 12, 2023 at 6:40 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Possibly an exhaust leak at one of the manifolds.
  10. Sep 13, 2023 at 12:33 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    For 7 k CDN with 200k plus on the motor,I would of just had the entire motor rebuilt.
  11. Sep 13, 2023 at 4:43 AM
    tak1313
    tak1313 Well-Known Member
    2013 Base 2WD
    7k CDN? HOLY CURRENCY CONVERSION!!! Maybe I'm too much of a cheap@ss combined with being too old, but that sounds like a replacement engine.
  12. Sep 13, 2023 at 8:46 AM
    BluberryBCtaco
    BluberryBCtaco Making the magic happen
    BC Canada
    2007 Tacoma Sport DCLB
    3in lift, Tow package, Any time 400w inverter, in cab outlet, vinyl floor, roof rack
    Welcome to Canada. Where everything is super expensive.
