P0021 - 2007 Toyota Tacoma 4.0L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Renengade, Apr 21, 2020.
  1. Apr 22, 2020 at 6:50 PM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    Might want to figure that out before ripping more stuff off your truck.
  2. Apr 22, 2020 at 7:01 PM
    Renengade
    Renengade [OP] Member
    Beyond just putting a multi-meter on it, it is a fairly simple part. It shows 0.9 ohms bouncing a little lower at times. Not sure on that one what else to do. I need to repair the timing cover leak anyways so I am not taking anything apart that does not need to come apart to do that job.
  3. Apr 22, 2020 at 7:02 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I wonder if the oil pump is intermittently failing. Isn't there a (pressure relief) spring loaded valve in the oil pump that could stick open and let oil pressure go back down into the pan? It's weird that you saw that oil pressure warning light around the same time the check engine light came on, but your pressure readings look pretty good.
    If it lost pressure for just a minute it could allow the chain to slip a tooth or two at the cams. Are you sure you didn't hear any rattling when the oil pressure warning came on?
  4. Apr 22, 2020 at 7:33 PM
    Renengade
    I am pretty sure there was no rattling but I was with someone and we were discussing it, so I could have missed it, if it was brief. The CEL came on and the oil pressure light came on a few miles later maybe 10. I will know tomorrow if the timing chain slipped a tooth. Not sure how to diagnose the oil pump. Looks like it is behind timing cover?
    b_r_o[QUOTED] likes this.
  5. Apr 22, 2020 at 7:38 PM
    j_sav115
    j_sav115 Well-Known Member
    SC
    07 Silver TURD SPRT
    Getting to start all over :)
  6. Apr 22, 2020 at 7:52 PM
    Renengade
    sounds like you are referring to the oil control valves a.k.a. variable valve timing solenoids? I think they are the same thing. I had a P0022 and P0012 come and replaced the OCV’s and it switched to the P0021. So don’t think they are the problem unfortunately
  7. Apr 23, 2020 at 5:16 AM
    j_sav115
    SC
    07 Silver TURD SPRT
    Yea that's what I meant, oh well good luck man! Keep us posted for future info
  8. Apr 23, 2020 at 7:09 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Have you tried reinstalling the original OCV for the side with the P0021 yet? To try ruling out a faulty new part?
  9. Apr 24, 2020 at 6:39 AM
    Renengade
    I have not tried reinstalling the original OCV, I did test the new one and it is at 7.9 while the old ones were testing at like 7.2.
  10. Apr 24, 2020 at 9:17 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Should be a quick 5 minute swap. Just to rule out any possibility.
  11. Aug 5, 2021 at 1:24 PM
    Dwray44
    Dwray44 New Member
    2009 Toyota Tacoma
    4inch lift,295 tires, fog replaced with pods, two JL 10w3 's where the back storage was and a bed cover.
    I’ve had a similar issue. I’ve got a 2009 Toyota Tacoma and had to take it in for an oil leak. Tool it the the dealership and they had to replace the timing chain cover and the seals and gaskets. Also replaced the water pump. I got the vehicle back and it had the check engine light on with a P0020 code. I took it back multiple times and they said they would fix it but each time they never did. It also never had the check engine light on when it came in.I’m not to sure what to do. Any help would be appreciated it
  12. Sep 16, 2024 at 8:45 AM
    n0madoma
    n0madoma New Member
    Old thread but I'd be very interested if the OP figured this out? Having the same issues with my 09 after vvt's replaced and new timing chains and phasers.
