p0022 code
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTimmy, Apr 2, 2012.
  1. Apr 2, 2012 at 5:42 PM
    TacoTimmy
    TacoTimmy [OP] Active Member
    Hohenwald, TN
    07 PreRunner SR5
    Driving home from work today my ultra gauge alarm went off and it said pending tc p0022. I googled it when I got home and it said camshaft position sensor. Before I go any further, I thought I would check with you guys. I have an 07 4.0. The check engine light is not on. Just says pending...any help is appreciated!
  2. Apr 2, 2012 at 5:47 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Clear it, and see if it comes back. Pending codes are codes thrown when the ECU detects something at the extreme of its operating range, but still within normal operational limits.
  3. Jul 24, 2014 at 6:41 PM
    Toyotamudbogs
    Toyotamudbogs Well-Known Member
    Devin
    White Springs , FL
    06 Tacoma 4x4, 4 door sr5
    Tintedwindows,Rockforfosgate amp 2 10" sub , fire dept radio,Rock sliders, Body Armer front Bumper, CB, 3'' EZ leveling kit, fog light mod, beep on lock mod, front duallys rigid led lights, rigid led flasher kit
    Did you ever fix this
  4. Jul 24, 2014 at 7:19 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    P0022 - Camshaft Position "A" - Timing Over-Retarded (Bank 2)
    cam timing: With warm engine and engine speed of between 500 rpm and 4,000 rpm, all conditions (a), (b) and (c) met (2 trip detection logic)
    (a) Difference between target and actual intake valve timings more than 5°CA (Crankshaft Angle) for 4.5 seconds.
    (b) Current intake valve timing fixed (timing changes less than 5°CA in 5 seconds)
    (c) Variations in VVT controller timing 19°CA or less of maximum delayed timing (retarded)
    Causes:
    • Valve timing
    • Oil control valve (OCV)
    • OCV filter
    • Camshaft timing gear assembly
    • ECM
    From what I understand the most common problem is the Oil Control Valve and / or Filter.
  5. Jul 25, 2014 at 8:35 PM
    Toyotamudbogs
    Devin
    White Springs , FL
    So change the oil filter. And see if this works ?
  6. Jul 26, 2014 at 1:55 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    No. The Oil Control Valve Filter.
  7. Jul 26, 2014 at 4:09 AM
    Toyotamudbogs
    Devin
    White Springs , FL
    Do you know where that is
  8. Jul 26, 2014 at 5:19 AM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    It's pretty much beneath the front exhaust port on each head. U will see a bolt just chilling there and it's behind the bolt. The bolt is what olds the filter in.
