P0022 help! At a loss
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sarubaru, Nov 5, 2024.
  1. Nov 5, 2024 at 8:41 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Here's the whole 1GR booklet.
    Dm93 likes this.
  2. Nov 5, 2024 at 8:44 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Yea I have it, I just posted the relevant pages pertaining to VVT oil flow.
    TnShooter[QUOTED] likes this.
  3. Nov 5, 2024 at 8:54 PM
    Sarubaru
    Sarubaru [OP] Member
    Sarah
    2009 Tacoma 4x4
  4. Nov 5, 2024 at 9:01 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
  5. Nov 5, 2024 at 9:03 PM
    TnShooter
    Deogee
    STOCK
  6. Nov 5, 2024 at 9:07 PM
    TnShooter
    Deogee
    STOCK
    The timing marks are on the phaser.
    If it's stuck, it will cause issues.
    Even more when you "retime" it.
  7. Nov 5, 2024 at 10:31 PM
    Bishop84
    Bishop84 Well-Known Member
    I've seen phasers fail on the 1GR. You can usually physically see it.
    For clarification can you tell us which side is bank 1 and 2? We gotta ask the stupid questions.
    Next @TnShooter or @Dm93 there's a "techtip" for p0022 where you check the cam journal if you can share it. It's not likely but its good to see all data.
    I always claim timing chains on here and this sounds like it, maybe a photo of the chain tensioner through the port would be a good reference. The stumbling doesnt add up to chain though.
  8. Nov 5, 2024 at 10:53 PM
    Sarubaru
    Sarah
    2009 Tacoma 4x4
    Bank 1 is passenger side and Bank 2 is driver side of course.
    Would love to see any tech tips that you might have.
    We can snap a photo of the tensioner tomorrow evening and post it. Here are some photos I have on hand in the meantime
  9. Nov 6, 2024 at 12:15 AM
    4x4spiegel
    4x4spiegel Well-Known Member
    Sorry you are having your troubles but this is a very interesting thread . Reminds me of Click and Clack show !!
  10. Nov 6, 2024 at 4:54 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I'm not seeing anything.
  11. Nov 6, 2024 at 6:15 AM
    Bishop84
    Dang. I see it.
    the removable cam bearing gets installed incorrectly and causes this code. It’s the just of it it. A photo of said bearing might be enough.
    TnShooter and Dm93[QUOTED] like this.
  12. Nov 6, 2024 at 11:15 AM
    TnShooter
    Deogee
    STOCK
    Nothing on Chilton either.
  13. Nov 6, 2024 at 12:21 PM
    Sarubaru
    Sarah
    2009 Tacoma 4x4
    Cam bearing as in cam cap? Which one can be installed wrong? They’re installed in numeric order and all markings face the correct direction.
    I’m planning to verify oil moves through the OCV and into the passages in the cam.
    I’ll remove the #1 Cam cap and crank the engine with the OCV installed unpowered and verify it has good pressure coming through the oil passage in the cam cap.
    Then repeat with the OCV powered with 12v from the battery to verify it comes out the other passage.
    Thanks to @Dm93 for the idea. I wouldn’t have thought to try this without you.
    TnShooter likes this.
  14. Nov 6, 2024 at 1:33 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    This seems plausible.
  15. Nov 6, 2024 at 1:57 PM
    #35
    TnShooter
    Deogee
    STOCK
    Did they give the clearance spec?
  16. Nov 6, 2024 at 2:14 PM
    #36
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I haven't persued it any further but it looks to me like that bearing can be installed improperly and block the oil holes.
    FastEddy59 and TnShooter[QUOTED] like this.
  17. Nov 6, 2024 at 6:42 PM
    #37
    Sarubaru
    Sarah
    2009 Tacoma 4x4
    There is no bearing. While we were in there we decided to check the clearance and it looks to be in spec. It was between .002 and .0015
  18. Nov 6, 2024 at 6:58 PM
    #38
    Bishop84
    It looks like the bearing is in bank 1 intake cam only. Not bank 2.
  19. Nov 6, 2024 at 7:17 PM
    #39
    Sarubaru
    Sarah
    2009 Tacoma 4x4
    Here is a link to a video of us testing the ocv. Look like oil is not making it through the ocv on bank 2 when it’s on, even though it actuates and will stall the engine in bank 1.
    Seems like a weird niche failure.
    Ordering the parts tomorrow. Will report back if new ocv fixes the problem.
    https://youtube.com/shorts/4c5dSNE6L4E?si=O0E8d4WHLNH7JAQj
    Leomania and Dm93 like this.
  20. Nov 7, 2024 at 11:33 AM
    #40
    TnShooter
    Deogee
    STOCK
