P0022 VVT-i Problems (Toyota told me 3k in repairs)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BarefootBandit, Sep 12, 2017.
  1. Sep 12, 2017 at 9:09 AM
    BarefootBandit
    BarefootBandit [OP] Well-Known Member
    TC UCA OME 884 5100 TSB+AAL 4.10 V6 6spd 285/75/16
    Hello all
    My 2006 Toyota Tacoma just rolled over 100,000 miles. Around the same time I had code P0022 come up and the truck began to run rough at idle. The code states "Camshaft timing over-retarded"
    According to my searching on here, it's a problem with the Variable Valve Timing (VVT).
    I brought it by Toyota to see if they could take a look at the OCV (Oil Control Valve) for the VVT. They said they checked it and it was fine, and they said that it is most likely a problem with the timing chain itself.
    They quoted me $700 teardown time just to check if that's the case, and over $3,000 in repairs if there actually is a problem with the timing chain.
    My questions now are:
    Is there any chance that they completely ignored the OCV and they are just trying to scam me out of $3,000?
    Can I ignore it and drive it the way it is?
    Is there any chance the timing could cause the valves to crash into each-other or crash into the piston?
    Toyko Joe likes this.
  2. Sep 12, 2017 at 9:12 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    @Tacoma Mike, I figured you might be able to give some insight on this.
  3. Sep 12, 2017 at 9:18 AM
    Toyko Joe
    Toyko Joe Here for the pictures
  4. Sep 12, 2017 at 9:25 AM
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
    Get another opinion.
  5. Sep 12, 2017 at 10:04 AM
    Tacoma Mike
    Southern Maine
    Great
    Throw me under the bus... Lol
    Check your oil level.
    More than once I fixed that code with adding 2 quarts to a low level.
    Techs use the computer to run the vvti controller.
    They can see the results.
    It everything checks out then you can try to clean the screens and replace the vvti controller.
    Just because it tests good doesn't mean it is all the time.
    We start seeing this over 100,000 miles.
    Rarely it is a controller but I always ask how far they want to go with it.
    It's a long time consuming pita.
    If you are tearing down the engine to change the vvti unit your sure as heck should be changing
    Both and chains, guides etc.
    Do it once cause if I recommend it and you decline and 3 weeks later the other bank acts up your paying again.
    It won't clash valves. Until the chain breaks if the vvti is flopping.
    If the engine is noisey at times in the vvti area then I would be saving pennies and not driving.
  6. Sep 12, 2017 at 11:38 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Picture of the screen location? A lot of people are unfamiliar with that component, and where to find it on the heads.
  7. Sep 12, 2017 at 1:41 PM
    Tacoma Mike
    Southern Maine
    Post #3 has a link to pages of this and locations for you
    Torspd[QUOTED] and Toyko Joe like this.
  8. Dec 29, 2017 at 8:50 AM
    Critical
    Critical New Member
    In case anyone isn't mechanically inclined and has to go to the dealership for this -- $648 (tax inc) was my bill for replacing the OCV
    hunter357mag likes this.
  9. May 3, 2018 at 12:34 PM
    BarefootBandit
    Small update: Been driving it since that day. 6 months and 12,000 miles later, it's still running. Still got the same vibration throughout the whole truck when at idle RPM's.
    If I've gone this far with it the way it is, I should be fine
