P0031 Bank 1...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JagerB0MB, Jan 15, 2020.
  1. Jan 15, 2020 at 12:22 PM
    JagerB0MB
    JagerB0MB [OP] Active Member
    2011 Barcelona TRDOR
    Recently had an intermittent check engine light. I have discovered that it is throwing code P0031, which I understand is a faulty Air Fuel sensor Bank 1 Sensor 1. Was about to order a part then realized that I’m not sure what side Bank 1 is. Found a thread on TW that said Bank 1 is passenger side but is the passenger side left or right? Seems simple but if someone could point me in the correct direction would be greatly appreciated!!
    Larzzzz likes this.
  2. Jan 15, 2020 at 12:58 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Bank one is the passenger side. Look for leaks first.
  3. Jan 15, 2020 at 1:03 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Passenger side is passenger side. Bank 1 is the first sensor of the two so the one which is closest to the exhaust manifolds. It's a pain in the rear to get to, not as much as bank 2 sensor 1 though.
  4. Jan 15, 2020 at 1:37 PM
    JagerB0MB
    Understood, thanks for the info so far. The question I’ve got is when ordering the part it is labeled left or right. Not passenger/ driver. I’m just double checking to make sure, seen heard conflicting information. Passengers side/ bank 1 = left?
  5. Jan 15, 2020 at 9:25 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  6. Jan 15, 2020 at 9:28 PM
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
    Pretty sure passenger side = right
  7. Jan 15, 2020 at 9:30 PM
    Bishop84
    Bishop84 Well-Known Member
    Right upstream.
    Denso is best choice.
    TnShooter likes this.
  8. Jan 15, 2020 at 10:27 PM
    JagerB0MB
    Perfect thank you!
    Exactly what I needed to know thank you.
    You guys are lifesavers :thumbsup:
    TnShooter[QUOTED] likes this.
  9. Jan 16, 2020 at 2:27 AM
    Larzzzz
    Larry
    MA
    Any V block motor that I've seen has the cylinders staggered. The forward most cylinder is always #1
  10. Jan 16, 2020 at 6:23 PM
    Greenedmc
    Greenedmc Well-Known Member
    Daniel
    Elizabethton TN
    2014 Silver Tacoma Trd Off Road Access cab
    You could also swap bank 1 and 2 sensors and see if the code follows to verify the sensor is bad.
  11. Jan 18, 2020 at 3:55 PM
    JagerB0MB
    Thanks for the tip!
    True didn’t thing of that, I figured they were the same sensor just the length of the connector on one side is shorter than the other.
