P0031 code
Discussion in '1st Gen. Tacomas (1995-2004)' started by Lachicory, Oct 23, 2022.
  1. Oct 23, 2022 at 8:01 PM
    Lachicory
    Lachicory [OP] Member
    04 Tacoma automatic 3.4L 4x4
    Found it's b1s1 a/f sensor and found the location for b1s1 and b1s2 sensors. What about b2s1& b2s2 locations? Does this truck have a/f and 02 sensors on bank 1? Can't seem to locate them. Can someone help? I read somewhere that b2s1 was located driver side near the exhaust manifold?? I'm trying to replace all the a/f and 02 sensors.
  2. Oct 23, 2022 at 8:02 PM
    Lachicory
    Oops, I meant does it have those 2 sensors on bank2 and if so, WHERE are they?
  3. Oct 23, 2022 at 8:11 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The best I can remember, it only has 1 A/F and 1 O2.
    A/F is before the cat. O2 is after.
  4. Oct 23, 2022 at 9:34 PM
    Lachicory
    Thanks, I'll get those "2" sensors ordered from Rock Auto and get them swapped out ASAP.
  5. Oct 23, 2022 at 9:53 PM
    02hilux
    Planet: EARTH
    Make sure to order Denso only
    Area51Runner likes this.
  6. Oct 23, 2022 at 10:43 PM
    Lachicory
  7. Oct 23, 2022 at 10:49 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
  8. Oct 24, 2022 at 6:43 AM
    Lachicory
    Yeah, I know, but this truck is 18 years old, I am just replacing both as a precautionary measure. You got any advise on front rotor upgrades? I've only ever replaced the pads/rotors once (2011) and due again, thought I might upgrade to something better? Or do you think better to just replace oem?
  9. Oct 24, 2022 at 6:45 AM
    YotaGangYotaGang
    YotaGangYotaGang PreRunners are wannabe 4x4’s
    Covina
    95, 97, 01 Tacoma | 06 Tundra | 07 FJ Cruiser | 08 Prius
    A rtt i never use and 30 light bars
    its just a big hunk of metal but for the pads ii ise akebono
