P0031/P0051 Fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wlmuncy, Apr 27, 2010.
  1. Apr 27, 2010 at 5:14 AM
    wlmuncy
    wlmuncy [OP] Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    I posted a thread about my "new" truck purchase. In that I mention the problem I was having with getting P0031 and P0051 error codes. Now I am posting the fix (in my case at least). If anyone else gets both codes at the same time.
    1) I grabbed the FSM from this thread. http://www.tacomaworld.com/forum/2nd-gen-tacomas/89275-05-tacoma-repair-manual.html
    2) Found the section for my error codes.
    3) Followed it down to the place where both codes meet (AF Heater Relay).
    4) Found where the in cabin relay box was located. (Picture below behind the battery).
    5) Found the correct relay for the AF Heater- Pulled it out. Man It's a bitch I tell you. In the picture below the AF Heater relay is circled red.
    6) Pulled the Fog lamps Relay circled in gray (I tested this one an it was good- fog lights worked)
    7) Switched them.
    8) Restarted truck. No CEL. No battery clear. Truck is suppose to clear the CEL after start up once condition is cleared.
    9) Drove around. Restarted a dozen more times. No CEL.
    Hope this helps you.
    LbcBob likes this.
  2. May 24, 2010 at 8:28 PM
    tonkatoy
    tonkatoy Well-Known Member
    Billy
    Phoenix, AZ
    08 White TRD Sport Acc 4x4 6 spd
    Thanks for posting the code and solution...
    I just got this code today. Did you replace the upstream
    o2 sensors first? I thought this code was to just change out the sensors. Why did you end up changing out the relays?
    Thanks,
  3. May 25, 2010 at 5:45 AM
    wlmuncy
    William
    Knoxville, TN
    The relay test was less expensive (free) and once it was corrected the codes went away. I have not had them again since. The reason I did not just replace the O2 sensors is I found it odd both would go out at the exact same time, also when I had the code read, the guy at the autoparts place thought it odd as well. So the relay was the common meet me place for both of these.
  4. May 26, 2010 at 9:44 PM
    tonkatoy
    Billy
    Phoenix, AZ
    Of course, two wouldn't go out at the same time. Genious! You just saved money for two sensors that you wouldn't been able to return. I have just trouble code P0031. Not P0051. I just wish I knew which side of the engine it is on. The repair manual doesn't say. Just says upper and lower.
    Does anyone know?
  5. May 26, 2010 at 10:04 PM
    BeefTaco
    BeefTaco WESTern Alliance: NORCAL COAST
    Santa Cruz County Ca.
    DTC
    P0031
    Oxygen (A/F) Sensor Heater Control Circuit Low (Bank 1 Sensor 1)
    HINT:
    Bank 1 refers to the bank that includes cylinder No. 1. Bank 2 refers to the bank that does not include cylinder No. 1. Sensor 1 refers to the sensor closest to the engine assembly. Sensor 2 refers to the sensor farthest away from the engine assembly.
    1GR-FE
  6. Apr 7, 2011 at 3:36 PM
    toytaco1
    toytaco1 Well-Known Member
    jed
    moreno valley
    05 supercharged trd off road
    trd supercharger, TRD intake, magna flow exhaust, JBA headers, walker evans front, fox rear, leaf pack, drilled slotted rotors, All Pro Front Bumper, Warn 8000 Winch
    I just popped 5 codes p0031 p0051 p0037 p0057 and p0430
    and this is after I had trouble starting the truck would the efi cause these codes to all come up at the same time? Also the truck has no power like it is in limp mode, it ran fine then all of a sudden it started to run really bad any help would be appreciated
  7. Apr 7, 2011 at 3:56 PM
    wlmuncy
    William
    Knoxville, TN
    Is there something in your exhaust pipe. None of those codes have anything to do with transmission issues which will put you in limp mode. All have to do with cat issues, but I would not think a failed cat would make the car limp, however, a stopped up exhaust system might.
  8. Apr 7, 2011 at 4:49 PM
    toytaco1
    jed
    moreno valley
    Im gonna try and replace the af heater relay and see if that clears the symptoms, toyota said total cost would be over 4 thousand. The truck ran fine then within 24 hours started running the way it is, Im thinking that the cats are fine it only has 69k miles.
  9. Apr 7, 2011 at 6:37 PM
    toytaco1
    jed
    moreno valley
    I did what you did and replaced the air fuel relay and cleared up the problem, tjanks for the post saved me some major dough
  10. Feb 18, 2014 at 6:33 AM
    tacoma73
    tacoma73 New Member
    06 Tacoma
    I also had error codes P0031 and P0051. After reading this post, I replaced the aforementioned AF relay and the CEL cleared (needed to disconnect battery to reset CEL).
    Thanks again.
  11. Feb 18, 2014 at 8:48 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    He is referring to the fuel air mix " Limp Mode ". This is where the system stays in an Open Loop and will run like shit and consume gas like crazy but it will get you home, usually. The fuel system is not adjusting A/F Ratio to the feedback from the sensors.
  12. Apr 9, 2014 at 2:02 PM
    X moked U
    X moked U Well-Known Member
    URD ShortShifter/URD True Cold Air Intake/RedHydroshield/Magnaflow Exhaust/Doug Thorley Long Tube Headers/Vibrant Ultra Quiet Resonator/URD MAF CAL/Coupe Weighted Shift Knob/IKH20s/MT-90/Ultragauge/Evo Mod/Recessed Grill Mod/Red powdercoat devil horns/Painted X brace/Black wheels/Black Chrome Sport headlights w/6000k bi-xenon/Pioneer AVH-4500 appradio /avs-vent visors/Weathertech Mats/Hula Girl & some other crap
    This did not work on my truck :/
  13. Nov 24, 2014 at 4:24 PM
    jimbo808
    jimbo808 Well-Known Member
    Kapolei, Hawaii
    05 TRD Sport 4x4
    Debadged, Mbrp cat back turn down, Afe drop in filter, Icon extended travel, Light Racing ucas, Dakars, Icon 2.0 vs monotubes, 285/70r17 goodyear kevlar Mtrs, Morimoto Minis D2S' bhlm with blacked out bowls, Bamf Sliders, pelfrey single hoop front bumper, smittybilt X20 10k, pelfrey ifs skid, pelfrey trans skid, all pro rear with side plates, sway bar removed, front superbumps, Avec 20 inch light bar, rigid flood fogs
    i appreciate the guide, it got rid of my light :D.
  14. May 8, 2015 at 6:26 AM
    Scott Smith
    Scott Smith Member
    Scott
    Arkansas
    2019 Tacoma double cab
    Thanks for the post on using the fog relay to test the heater relay. This worked for me and saved me many hours of trouble shooting. I picked up a new relay at the local ABC autoparts store and now everything works and the check engine light went off.
  15. Feb 16, 2018 at 1:39 PM
    omarchavezorozco
    omarchavezorozco Member
    Omar
    2012 White Tacoma TRD sport
    Just tires
    Thanks a lot, I had the same issue, same codes and fixed it with the relay swap. In my case I didnt had the fog relay but I swapped with the Horn relay. In my case this error appeared just after I washed the interior with a Karcher.
  16. Jan 4, 2019 at 12:32 PM
    Lukealive530
    Lukealive530 Member
    Luke
    2014 Dopeass Tacoma
    Thank you for this ! I just got both P0031 and P0051 codes on my 2014 Tacoma. Figured it was something easy like a relay. On my truck, however there is a second relay box behind the fuse box under the hood. None of them are labeled though. Are these extra relays? They look similar to the relays used for the heater. If anyone is certain, please give me a response. Much thanks!
  17. Jan 4, 2019 at 1:15 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Look here: https://www.customtacos.com/tech.ol...oyewd/06toypdf/ewd/2006/tacoma/f/em01d0up.pdf
    Relay box # 2 ( Engine Room R/B No. 2 )
  18. Jan 4, 2019 at 1:21 PM
    DC-USAF
    DC-USAF Well-Known Member
    Dale
    WNC
    2015 SR5 Access Cab 4x4 V6
    TRD PRO Grill, mobtown offroad recovery bar, SCS Ray 10's
    Those five codes are for the emissions system. I have the same codes coming up on my truck and I keep resetting it with my ultraguage. I did have Toyota check it out and the say I need to have the charcoal canister that's on top of the gas tank replaced, parts and labor would be around $800.
  19. Jan 4, 2019 at 5:57 PM
    Lukealive530
    Lukealive530 Member
    Luke
    2014 Dopeass Tacoma
    The pictures are nice but in my truck, the layout for the fuses is much different, which makes sense, since it's a newer modem. However I feel like theres a different issue going on than just it being relays. Its weird to have the same relays going bad all across different years of this vehicle in the same circuit. And with these codes I have a CEL and traction control off light. What does this relay have to do with traction control?
  20. Apr 3, 2019 at 8:15 PM
    Nightmare38oh1
    Nightmare38oh1 Member
    Jake
    Salt Lake City
    07 Trd sport double cab long bed 4wd
    Pro comp level, 17x9 MB 11 with 265/70r17 bfg ko2
    Not to dig up an old thread but I’ve been battling this issue for a while now. The relay issue didn’t help me. So assuming worst case scenario I went ahead and did the 02 sensors. They looked original so why not at this point. Any other ideas or possible fixes for this? I’ve tested all efi fuses and all checks good. Is there a chassis ground somewhere I’m missing that might be affecting this?
