P0051 Error Code
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rak8886, Feb 17, 2020.
  1. Feb 17, 2020 at 1:25 PM
    rak8886
    rak8886 [OP] New Member
    2018 Tacoma TRD Pro 3.5L
    CEL came on and I found the issue. Not sure if I can solder the wire, so where can I find the wiring harness with female connector for the o2 sensor to replace?[​IMG]
  2. Feb 17, 2020 at 1:49 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
  3. Feb 17, 2020 at 1:53 PM
    rak8886
    Thank you! I'll order this. Would I be able to just clip the excess wires and solder the new wires to the current wires that's connected to the truck?
  4. Feb 17, 2020 at 2:24 PM
    Ronzio
    Pennsylvania
    17 DCSB TRDOR
    Either way you got to solder it and heat shrink to keep the green puss away. You need accessibility to make a good repair. The area looks tight. I would depin the one bad wire and make repair.
  5. Feb 17, 2020 at 2:29 PM
    rak8886
    good to know, thanks for your response!
