P0100 and p0110 code with no cell
Discussion in '4 Cylinder' started by Stout890, Dec 18, 2011.
  1. Dec 18, 2011 at 3:16 PM
    Stout890
    Stout890 [OP] Well-Known Member
    Palmdale ca
    99 prerunner sr5
    Navigation, 10" sub, ome881 on billies 3" all-pro leaf springs with billies, taneau cover, k&n intake,axle swap with a E locker. 31" BFG A/T on premium wheels, hoola girl air freshener and a broadie knob!
    So I got my scan gauge today as an early Christmas gift from the girl friend and I got it all hooked up nice and found out I have a p0100 and p0110 code. The p0110 is a bad IAT sensor and the p0100 is a mass airflow malfunction. I don't have a cel popping up and truck runs fine except iv always felt it lacks power and it has bad mpg. I get about 15.4 mpg regularly. It's a 99 automatic with the 3rz
    Anyone had this symptom and fixed it? Or anyone have ideas as I'll be trouble shooting it. Thanks
  2. Dec 18, 2011 at 4:20 PM
    AlaskanTaco
    AlaskanTaco Well-Known Member
    Anchorage Alaska
    09 sr5 acc cab tacoma
    Sounds like it was unplugged at one point and someone started the vehicle. Make sure it is plugged in, clear the code, and if it comes back, then deal with it. EVERyONE has horrible mpg because of winter gas. That's all
  3. Dec 18, 2011 at 5:27 PM
    Stout890
    Palmdale ca
    99 prerunner sr5
    no my gas is always horrible lol and so cal doesn't get winter gas mixes im pretty sure.
    but yes i did recently unplug and clean the maf but i didnt start the vehicle but i reset the codes and drove a quarter tank of gas so far and no code again...so i will drive for another few days and update this thread with what happens
    but in the meantime what would the bad inlet air temp code be cause from? or is that sensor built into the MAF also?
  4. Dec 18, 2011 at 5:57 PM
    AlaskanTaco
    Anchorage Alaska
    If you look at your mac sensor, it is a 5 wire. 3 for maf (power ground and low ref) and 2 for iat. (power low reference). They should be built into each other.
  5. Dec 19, 2011 at 10:44 AM
    AlaskanTaco
    Anchorage Alaska
    *maf. Damn iPhones.
  6. Dec 29, 2011 at 4:44 AM
    SandStorm
    SandStorm New Member
    Arizona
    97 Taco 4x4 3RZ
    Hooptie Status
    I had the same codes on my '97 with no CEL.
    Turns out I had some damaged wires between the MAF/IAT and the main engine harness. PO had a ghetto intake system that I was replacing and I found the wires melted from being too close to the exhaust manifold (which was cracked and didn't have a heat shield). The engine ran like crap when it was warm due to the adjusted timing and fuel pressure from the ECM not having the correct MAF/IAT readings. After the wires were repaired it runs smooth as hell, warm or cold.
    You might try cleaning the MAF assy first and then checking continuity of the wiring from the MAF connector to ECM.
