P0102 code tacoma 2.7L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco0914, Jun 4, 2023.
  1. Jun 4, 2023 at 3:47 PM
    Taco0914
    Taco0914 [OP] Active Member
    Juan
    2014 black tacoma TRD SPORT
    None
    Sup guys hope I can get some help,
    Toyota tacoma 2.7L
    code p0102 Mass or Volume air flow circuit low input
    PERMANENT code how can I fix this issue
  2. Jun 4, 2023 at 3:53 PM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    Ohm out MAF - that will verify if its bad or not. Or throw a MAF at it.
  3. Jun 4, 2023 at 5:17 PM
    Taco0914
    Juan
    None
    But the check engine light is NOT on
  4. Jun 4, 2023 at 5:37 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    No check engine light?
    Does the engine run ok?
    You could disconnect the battery for 10 mins and then hook it back up.
    Other than that, you need to look at the data on a scan tool. If the engine runs fine, you may have an intermittent issue.
    Dm93 likes this.
  5. Jun 4, 2023 at 8:22 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Is the MAF plugged in?
    off the top of my head it probably needs a MAF sensor. But if you want to do some checks you could ohm it out and do resistance checks. Or pull up grams per second maf reading and calculated load in a scan tool
    Dm93 likes this.
  6. Jun 4, 2023 at 8:31 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    When you say permanent you mean it won't clear or it cleared but is stored as a Mode $10 (Permanent) code?
    Taco0914[OP] and TnShooter like this.
  7. Jun 4, 2023 at 8:45 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Are all the intake pipe clamps tight?
  8. Jun 4, 2023 at 8:49 PM
    Taco0914
    Juan
    None
    Yup all clamps are tight,
    And correct its a permanent code that I cant erease
  9. Jun 4, 2023 at 8:52 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    TnShooter likes this.
