P0125 and P1130 codes
Discussion in 'Technical Chat' started by Ptowntaco, Nov 5, 2009.
  1. Nov 5, 2009 at 9:48 PM
    Ptowntaco
    Ptowntaco [OP] Camburg :)
    Bryce
    Petaluma Ca.
    2000 Prerunner TRD
    Tint, Socked, Deck Plate mod, Camburg 2.5 coils, Camburg UCA, 5100's in the rear, Custom Deaver leaf pack, Micky Thomson Classic Locks, BFG KM2, CB
    My check engine light came on and i went and got the code read. It said that the o2 sensor was bad. I just changed that today and now it says the codes P0125 (Insufficient coolant temp for closed loop fuel control) I also have the P1130(Bad Mass Air Sensor).
    I just changed my Mass Air Sensor today so i dont know what else it could be? I was looking around on here and people said change your coolant. Any imput would help. :)
    Thanks guys, Bryce
  2. Nov 6, 2009 at 5:44 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Bank one sensor one (closest to the engine) Air/Fuel Sensor. For the P0125 code...Could be a bad thermostat. Fix the A/Fr sensor first, and see if it comes back.
  3. Nov 6, 2009 at 6:06 AM
    98tacoma27
    Ben
    Not Beech Creek
    As Chris stated for the P0125: there are several quick and easy things to check for this code before you invest in a new ECT sensor.
    http://www.obd-codes.com/p0125
  4. Nov 6, 2009 at 6:06 AM
    jfr02
    jfr02 Well-Known Member
    2012 dcsb 6spd sport
    yeah what cris said,changing the coolant will most likely do nothing.it is almost allways the thermostat and with everything else make sure you check wiring and conections.
  5. Nov 6, 2009 at 6:11 AM
    98tacoma27
    Ben
    Not Beech Creek
    Plus the thermostat is a drop in the bucket compared to the price of a new ECT.
  6. Nov 6, 2009 at 6:22 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    But change the AF sensor first, as that could be a contributing factor to throwing the coolant code.
