P0125 - Ugh!
Discussion in '4 Cylinder' started by JoshM, Apr 24, 2012.
  1. Apr 24, 2012 at 2:14 PM
    JoshM
    JoshM [OP] Active Member
    Franklin, TN
    1998 RCSB 4x4
    After installing my Doug Thorley header last weekend I got a P0125. After Googling, I came up with a bunch of things. But, after searching on here, Toyota had their own reason for this code... the front O2 sensor / A/F sensor. Well, I ordered a new Denso from URD. I cleared the code via ScanGauge and put in the new sensor. Within 5 mins of driving the CEL came back on.
    Is there something that I may not know, that I may have overlooked? Or do I just need to continue down the list until the CEL goes away?
    Oh, I didn't disconnect the battery. I simply cleared it via ScanGauge. Could that be the/an issue?
    Edit : Disconnected battery. Same issue.
  2. Apr 24, 2012 at 5:39 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    I'd check for exhaust leaks. :notsure:
  3. Apr 24, 2012 at 5:50 PM
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
    :) Josh, I looked up P0125, and it is: insufficient coolant temperature for closed loop fuel control. This is not any where around the O2 sensor, but may be one of the temperature probes that connect to the engine. You have two sensors, one is for your temp gauge on the dash and one for the ECM or computer.
    I looked the sensor you want on autozone and this is the link to it.http://www.autozone.com/autozone/parts/1998-Toyota-Tacoma-2WD/Coolant-Temperature-Sensor/_/N-ja5cpZ9gslt
    There is your other sensor, this one is for the temperature guage. So you won't mix them up. http://www.autozone.com/autozone/parts/1998-Toyota-Tacoma-2WD/Temperature-Switch/_/N-ja5cpZ9gsmf
    I think if you change sensor, you should see your light go out. GOOD LUCK.
