P0128 Error Code CEL
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sparkle_Tooth, Mar 22, 2024.
  1. Mar 26, 2024 at 1:11 PM
    Sparkle_Tooth
    Sparkle_Tooth [OP] Well-Known Member
    East TN
    2020 TRD PRO (Magnetic Gray)
    ICON Stage 9 BFG KO2 285/75R/16
    Well it can seep for 300K and it really wouldn't matter given its location. Im not going to say it doesn't bother me but its really not that big of a deal to be honest.
  2. Mar 26, 2024 at 1:14 PM
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    Another thing to keep in mind is all vehicles seep oil . I see it all the time on new cars that I work on . (I’m an autobody tech)
  3. Mar 26, 2024 at 1:15 PM
    Blak Shinobi
    Blak Shinobi Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
    nice , i was going to reveal my age but id rather not ,I can remember 20 years ago every car owner , it could of been family or friends they had trunk with cassettes,spare tire, car jack and at minimum a quart of oil in case they needed to add more oil.It was the norm back then , nowadays we sit and cry on the internet and people get their feelings hurt really easily , pathetic lol
  4. Mar 26, 2024 at 1:23 PM
    Sparkle_Tooth
    East TN
    Here is the TSB I was referring to
    Please see T-SB-0008-20
    Applicability:
    Introduction:
    Vehicles may display evidence of a fluid leak or fluid seep from powertrain components. This bulletin explains how to determine the differences between a fluid leak versus a fluid seep. Cases that are determined to be a “leak” should be repaired accordingly and will be covered under warranty if applicable. Cases that are determined to be a “seep” should be documented on the repair order and inspected at the next service interval. Follow the Repair Information in this bulletin to determine if the concern in question is a fluid leak or fluid seep and review the Repair Procedure section to address the condition.
    Note:
    This bulletin applies to ALL powertrain fluids excluding fuel and coolant
    APPLICABLE WARRANTY:
    • Warranty coverage is based on the failed component. Please refer to the Warranty Policy and Procedures Manual and the Powertrain Parts List for specific coverage. • Warranty application is limited to occurrence of the specified condition described in this bulletin.
    These conditions are usually covered under your 5year/60,000 miles powertrain warranty or a CSP, LCS, SSC.
    Warranty Claim Submission: Warranty Policy 4.21:
    • ANY leak repair to be performed under warranty requires photo documentation of the active leak
    • This Documentation showing the cause of defect MUST be created prior to the start of the repair and attached to the warranty claim.
    • Photos MUST be clear and provide perspective image(s) that identify the affected component(s) and close up image(s) that illustrate the defect or condition.
    • For additional information regarding application and eligibility please reference Warranty Policy 4.21
    Repair Information:
    Leak Definition
    A leak is verified by the identification of pooling fluid with the formation of droplets and dripping. Below are examples determined to be a leak.
    Below are examples determined to be a leak.:
    Seep Definition
    A seep is defined as a thin accumulation, film, or coating of oil on the exterior of a component. The area often has a darker or damp appearance compared to the rest of the part and may attract dust or dirt over time.
    Note:
    Seepage is a normal condition seen at mechanical joints that does not require repair but should be noted on the repair order for future reference.
    Below are examples determined to be seepage.
    Repair Procedure:
    If a repair is needed, reference the information below to ensure an adequate repair:
    1. AFTER disassembly, clean, inspect and prepare each sealing surface BEFORE reassembly:
    A. For Joints Sealed with Gaskets/ O-Rings/ Seals:
    (1) Clean: Remove ANY gasket material stuck to each sealing surface.
    (2) Inspect: Check the sealing area for ANY surface imperfections (pitting, grooves, gaps, etc.) and replace part if necessary.
    (3) Prepare: Remove ALL oil residue and wipe each surface with the appropriate cleaner and allow to dry.
    (4) Install a NEW gasket and reassemble components per the applicable repair manual.
    B. For Seal Packing/ Form in place Gasket (FIPG) Sealed Joints:
    (1) Clean: Remove ALL sealant from each surface
    (2) Inspect: Check the sealing area for ANY surface imperfections (pitting, grooves, gaps, etc. replace part if necessary)
    (3) Prepare: Remove ALL oil residue and wipe each surface with the appropriate cleaner and an oil-free cloth. Allow to dry BEFORE applying new seal packing.
    (4) Apply new seal packing to appropriate areas and reassemble components per the repair manual within 3 minutes of applying seal packing.
    (5) Allow at least 2 hours AFTER installation BEFORE adding oil.
    2. Confirm the repair is complete, test drive vehicle and make sure that there are no leaks from the repaired area.
    Marshall Man likes this.
