p0136
Discussion in '4 Cylinder' started by tedrowkj, Aug 11, 2010.
  1. Aug 11, 2010 at 6:52 PM
    tedrowkj
    tedrowkj [OP] Member
    Jeff
    Colorado
    97 Tacoma 2.7
    31s and wheels..
    my check engine light came on and the code i got says my o2 sensor behind the cat is malfuntioning.. anybody know any ways to bypass or get rid of the sensor or both of them?
  2. Aug 11, 2010 at 7:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Why not just replace the sensor?
  3. Aug 11, 2010 at 7:12 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Not sure how to bypass, but before you do anything reset the code and see if it comes back.
    My sister's CRV had the same code come up, shop told her 1,000 bucks to replace the Cat. She discoed the battery for a min, cleared code. (proud of lil sis!) So far, the light is still off. It came on during a road trip, and I have read that if you get a tank of gas that has too much oxygenation in it, that can cause the issue.
    Edit: I should clarify: Not sure which code she had, but the definition was "catalytic converter inefficiency". Your code is low sensor voltage, so maybe not the same thing. But, reseting the code is free and worth a try. If you really have an issue, it will come back quickly.
  4. Aug 12, 2010 at 4:59 PM
    tedrowkj
    Jeff
    Colorado
    97 Tacoma 2.7
    31s and wheels..
    i most likely will be replacing it i just wondered if there was an easier solution.. thats all
