P0153
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Green Jeans, Dec 2, 2020.
  1. Dec 2, 2020 at 3:32 PM
    Green Jeans
    Green Jeans [OP] 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
    P0153:
    o2 sensor slow circuit response bank 2 sensor 1.
    Threw this code today while the truck was warming up in my driveway.
    Day before the entire exhaust was removed to have a shop replace the clutch.
    After searching the forum I haven't found anyone that has reported on this code before, in a 2005-2015 2'nd gen Tacoma.
    Anybody have this happen to them? Remedies?
  2. Dec 2, 2020 at 3:59 PM
    Forumuser
    Forumuser Well-Known Member
    Rob
    2011 Tacoma 4x4
    Fox 2.5 front 2.0 rear, Camburg uca's, ubolt flip w/timbren bumps, afe intake, URD fuel kit, TRD S/C, URD 2.6pulley, URD 160 thermostat, URD Headers Y-pipe exhaust, short throw shift, innovate boost afr gauge, optima battery, URD heavy flywheel, stage 2 clutch, hydraulic throw out conversion
  3. Dec 2, 2020 at 4:15 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Crawl under the truck and look for damage to the sensor BEFORE (closest to manifold) converter on the Drivers side.
    Bank 2 = Driver side
    Sensor 1 = Closet to Manifold / Before Converter
    Jimmyh, Forumuser and Green Jeans[OP] like this.
  4. Dec 3, 2020 at 11:03 PM
    Green Jeans
    Oregone
    '13 TRD Off-Road
    Small leak. Code gone!
    TnShooter likes this.
  5. Dec 6, 2020 at 8:31 PM
    Green Jeans
    Oregone
    '13 TRD Off-Road
    Now I’m throwing a P0137!
  6. Dec 6, 2020 at 9:01 PM
    TnShooter
    Deogee
    STOCK
    Are sure you don’t have an exhaust leak?
    There are a few different ways to look for them, google “find exhaust leak”.
    Basically you need to pressurize the exhaust system and look/listen for leaks.
    You can use the engine to pressurize the exhaust (restrict the exhaust flow)
    Or pressurize the exhaust with an external air source ( blow air into the tail pipe, use soapy water)
    Like I said, just google it. There are many different ways to find a leak.
    If you don’t have a leak, then I’d maybe look at the O2 Sensor.
  7. Dec 6, 2020 at 9:11 PM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Sounds like the shop that did the clutch ain’t done with your truck. They removed the exhaust now your throwing exhaust codes. This isn’t likely a coincidence.
    Take it back to them.
