P0158 help?
Discussion in 'Technical Chat' started by ktmrider, Nov 16, 2010.
  1. Nov 16, 2010 at 2:48 PM
    ktmrider
    ktmrider [OP] Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    it just popped up, i have done no work in 6 months, just an alignment at the toyota dealer on saturday. 30k miles TRD supercharger with other modifications see below avatar.
    any recommendations on what to do?
    P0158 02 Sensor Circuit High Voltage (Bank 2 Sensor 2)
    Where is Bank 2 Sensor 2???
  2. Nov 16, 2010 at 3:03 PM
    ktmrider
    Junk
    Ive got a 02 simulator in the garage if that would fix my problem anyone?
  3. Nov 16, 2010 at 4:37 PM
    ktmrider
    Junk
  4. Nov 16, 2010 at 4:39 PM
    707tothe907
    707tothe907 Superior Member
    Jake
    Chico NorCal
    05 DCSB Off Road
    Just hit the clear button and your good.
    :D
  5. Nov 16, 2010 at 4:41 PM
    ktmrider
    Junk
    haha ive done it a couple times it keeps coming back.
  6. Nov 16, 2010 at 4:48 PM
    outlaw7
    outlaw7 Well-Known Member
    Brandon
    PacNorWest
    2010 trd sport
    Trey I had the same code was caused from gasket failure on my pipe bomb I used the ones supplied with the pipe bomb and the were shot when I removed and sold it 2 months ago went back to OEM y and new OEM gaskets haven't had the code since
  7. Nov 16, 2010 at 4:53 PM
    ktmrider
    Junk
    do you know if it was the gasket that connected the y pipe to the headers or the y pipe to the exit pipe with muffler
  8. Nov 16, 2010 at 4:57 PM
    outlaw7
    Brandon
    PacNorWest
    2010 trd sport
    It was the ones from header to ypipe
  9. Nov 16, 2010 at 4:58 PM
    ktmrider
    Junk
    oh I doubt it was that, i havent touched those.
  10. Nov 16, 2010 at 5:18 PM
    outlaw7
    Brandon
    PacNorWest
    2010 trd sport
    Try swapping both rear o2 and see if it trips again on the same side or if it goes to bank1
  11. Nov 16, 2010 at 5:35 PM
    ktmrider
    Junk
    dont make fun of me but the largest metric open end wrench i have is 17 and this is a 18 or 19. Im a bad mechanic lol. I guess im going to sears tomorrow. This wont hurt anything by driving on it will it?
  12. Nov 16, 2010 at 5:56 PM
    outlaw7
    Brandon
    PacNorWest
    2010 trd sport
    Dude I had the same issue had to borrow a adjustable crescent to swap mine out when I put in the pipebomb so I have no room to make fun. I don't think any harm will come I drove mine for 5 or 6 months and had to clear the code 5 or6 times. If it throws a p0152 then you will know the sensor is bad but if it throws the same code I would look into an exhaust leak somewhere
  13. Nov 16, 2010 at 5:58 PM
    ktmrider
    Junk
    yeah i thought about the crescent but i just dont want to fuck it up.
  14. Nov 16, 2010 at 6:05 PM
    outlaw7
    Brandon
    PacNorWest
    2010 trd sport
    Keep me posted with your findings
  15. Nov 16, 2010 at 6:29 PM
    ktmrider
    Junk
    Ok i got board and ended up getting them both off with a 7/8th wrench, but on the drivers side the rear has a longer cable so they couldnt be interchanged. the short passanger side couldnt reach the other side. so what I did after was I unpluged the passagner harness and started the truck and threw the same code. So this leads me to believe that my passanger side 02 sensor is bad.
  16. Nov 16, 2010 at 6:36 PM
    ktmrider
    Junk
  17. Nov 16, 2010 at 6:57 PM
    outlaw7
    Brandon
    PacNorWest
    2010 trd sport
    Sorry man I didn't know about the cables when I was troubleshooting mine someone on xru told me to try that but I never got around to item
  18. Nov 16, 2010 at 7:04 PM
    ktmrider
    Junk
    dont worry about it at least now I know how to take them out and put them back in.
  19. Nov 16, 2010 at 8:31 PM
    ktmrider
    Junk
    wait does anybody know what bank 2 sensor 2 means. or its location?
  20. Nov 16, 2010 at 9:11 PM
    ktmrider
    Junk
