P0171 and PO174
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MACKT28, Dec 19, 2024.
  1. Dec 19, 2024 at 1:54 PM
    MACKT28
    MACKT28 [OP] Well-Known Member
    2006DCLB
    Heretic Ditch lights Toyo Open Countrys AT2 HI VIS OVERLAND RTT
    Curious as to what fixes have been taken on these two codes taking the truck to the dealership tomorrow to have fuel injectors cleaned. Already did new MAF sensor. Was told to replace both upstream sensors. No rough running code goes off and comes back.
  2. Dec 19, 2024 at 1:58 PM
    MR5X5
    MR5X5 Well-Known Member
    Where did you get your previous MAF? Particularly import to go OEM on that one...
    Rougarou680 likes this.
  3. Dec 19, 2024 at 2:02 PM
    MACKT28
    2006DCLB
    I did the denso OEM one. But code was showing on and off prior to doing that so just checking things off the list from what I have read on the code readings. As well as getting all maintenance up to date before the beginning of the year which I do every year.
  4. Dec 19, 2024 at 5:41 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    You need to properly diagnose it or find someone that can properly diagnose it, lean codes aren't something you just throw parts at (really hardly any codes/issues are for that matter). First step aside from checking for obvious vacuum leaks is to look at fuel trim and AFR/O2 sensor data under various operating conditions to determine when it's running lean, how lean it's actually running, and if it's in fuel control or not. Then based on that data we can determine where/what to start testing.
    I'd also like to know is the intake system stock?
    b_r_o likes this.
  5. Dec 20, 2024 at 6:18 AM
    MACKT28
    2006DCLB
    I don't have a computer to diagnose that so I'm going to let my guy at toyota do that this morning. The truck does have a stock intake with a k&n filter in it which I don't see that being an issue but could be a factor but it's always had a k&n filter and I keep it cleaned and lightly oiled being we have the same air filters in all the boats we work on.
    mit88 likes this.
  6. Dec 20, 2024 at 6:19 AM
    MACKT28
    2006DCLB
    I also am gonna have them go ahead and replace the pcv and the hose on the truck being I haven't had that done since I've owned it.
  7. Jan 25, 2025 at 8:55 AM
    mit88
    mit88 Well-Known Member
    Planet earth
    So did you have the problem resolved? What did he find out?
  8. Jan 25, 2025 at 1:00 PM
    MACKT28
    2006DCLB
    A/F ratio sensors needed to be replaced fixed issue on the two codes. But went ahead and replaced pcv valve and as well did new spark plugs and had fuel injectors tested and cleaned.
