P0171+ P0120+ P1130
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacoluke10, Jul 12, 2025.
  1. Jul 12, 2025 at 9:01 PM
    tacoluke10
    tacoluke10 [OP] Well-Known Member
    Luke
    2002 Black Tacoma Prerunner
    Hey All!
    Anyone have any idea why I might've gotten all three codes at once?
    I just recently replaced the 02 sensor on my 3.4L V6 1st gen tacoma.
    P1130 came back shortly after replacing it. Although I just got fuel and the rest of the codes popped up.
    Can't figure this one out. Any help is deeply appreciated. Cheers.
  2. Jul 12, 2025 at 9:54 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Was it the upstream sensor or down stream sensor?
    P0171 is the upstream (A/F) sensor.
    P01130 is also for the Bank 1 Sensor 1 (A/F) Sensor.
    The P0120 is the TPS on the Throttle Body
    Let us know what sensor it was you replaced.
    As the O2 sensor is the Downstream sensor.
    Upstream = BEFORE the converter
    Downstream, is AFTER the converter.
    t0p_d0g likes this.
  3. Jul 13, 2025 at 8:29 AM
    Glamisman
    Glamisman Well-Known Member
    Are the parts you installed factory parts or ?
  4. Jul 13, 2025 at 12:30 PM
    tacoluke10
    Luke
    I replaced the upstream sensor if I remember correctly. I also since then had my break master cylinder and booster replaced at Toyota. I saw a video of someone saying one of the codes could be due to the seal on those.
    It was an aftermarket sensor. Although I dont think the sensor is the issue.
  5. Jul 13, 2025 at 1:03 PM
    eon_blue
    Azusa, CA
    I would be suspicious of the new aftermarket sensor if the same code persisted…Toyotas are notoriously finicky with aftermarket sensors. The p0171 could relate to that as well or possibly a vacuum leak related to the other new parts (booster, master cylinder) installed. I would check closely for any leaks in that area, or if it’s still under warranty for the install I would have them do it.
