P0171, P0174 CEL after seafoam?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 1TUFFTRD, Jul 10, 2014.
  1. Jul 17, 2014 at 4:34 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
  2. Jul 17, 2014 at 1:22 PM
    1TUFFTRD
    1TUFFTRD [OP] WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    I did this. Still ran sluggish and hesitates afterwards.
  3. Aug 5, 2014 at 12:15 PM
    1TUFFTRD
    1TUFFTRD [OP] WTF
    06 AC with a skewp
    06 With a Skewp.
    So after using more sefoam and two tanks of gas with lucas oil fuel treatment truck is back to its peppy self:notsure:
  4. Aug 5, 2014 at 12:41 PM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    Interesting. Personally Seafoam scares me and I won't use it. I ran it in my I4 Camry with 95K and it started burning oil so bad that it had to be rebuilt, and all I did was dump one can in the tank. I only had the car for 3000 miles, so was it doing it pre-Seafoam? Who knows, I just won't do that again.
  5. Aug 5, 2014 at 3:07 PM
    1TUFFTRD
    1TUFFTRD [OP] WTF
    06 AC with a skewp
    06 With a Skewp.
    I here you. I'm just wondering if the seafoam was the cause or not to my codes and hesitation/sluggish acceleration:confused:
    For now my truck is running good, so I'll keep my fingers crossed:eek:
  6. Aug 15, 2014 at 9:09 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Is this also after you replaced the AFR sensor?
    I don't believe seafoam is the immediate culprit. It may have dislodged some gunk and clogged something else but I doubt that it chemically harmed anything. I have used seafoam on several vehicles. One thing I did learn about using it on our 2nd gen tacomas is that you should not use the Brake Booster hose. It dumps all the cleaner into I believe the number 3 cylinder. It's best to use it through the vacuum hose on or directly after the throttle body.
    I just got these codes again. Last time was a few months ago while offroading, still not sure why that happened. This time I will scour the truck for vacuum leaks and soak an extra set of O2 sensors in seafoam to try to clean them.
