P0171 & P0420
Discussion in '1st Gen. Tacomas (1995-2004)' started by HenryG, Apr 27, 2021.
  1. May 2, 2021 at 3:08 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    :cheers: Beat me to it...
    eon_blue[QUOTED] likes this.
  2. May 3, 2021 at 12:40 PM
    HenryG
    HenryG [OP] Well-Known Member
    Washington State
    Hmm.. If I'm going uphill at highway speeds the lng trl will sit around 25-30 until I'm off the throttle. Temps are normal and power seems normal. I'm trying to baby it as much as I can as I make my way home. :notsure:
  3. May 3, 2021 at 1:46 PM
    crazytacoman
    crazytacoman Well-Known Member
    Tacoman
    Taco World
    02 2.7 doublecab & 07 4.0 doublecab
    Color Wheels
    I’ve had both of these codes. Ended up being related to small exhaust leak in the header and the exhaust pipe near the 1st O2 sensor. And the O2 sensors.
    I checked for the obvious by using a really bright flashlight at night and looking out for smoke. And by using the Chrisfix method of soap/water spray. https://www.youtube.com/watch?v=N-exs1iMLFU
    I’m pretty sure p0420 was due to my rear O2 sensor being out. Make sure to only replace these with Denso sensors from a reputable seller since there are a lot of threads of non-OEM and counterfeit-eBay sensors causing headaches.
    good luck
    Rastopher likes this.
  4. May 3, 2021 at 1:52 PM
    Heyyo_Friday
    Heyyo_Friday Circle driving enthusiast
    Derek
    Dfw, texas
    2020 tundra 1794
    Rays valve stem caps
    My thought is verify the maf is working and reading correct. If the maf is reporting more airflow or less airflow than the engine is truly using it could cause the ecu to think its running lean/rich based on what its getting from the maf. But I could be wrong. Im still learning slowing learning how maf systems work
  5. May 12, 2021 at 12:22 PM
    Rastopher
    Rastopher Well-Known Member
    Ras
    Sacramento, Ca
    2002 2.7 4x4 reg cab automatic
    Utility Shell, Ultra 062 wheels, bilstein 5100, OME880 coils, wheelers progressive AAL, Whiteline LCA bushings, poly sway bar and steering rack bushings, led dash cluster, shifter bushings, 4runner mirrors.
    i had both 0171 and 0420. It turned out to be a combination of a small exhaust leak, as well as a dirty maf. That being said, I drove the truck with those codes on for literally 110,000 miles without any issues whatsoever. Not a recommendation, but just saying that I wouldn’t lose sleep over trying to fix it on the road.
    crazytacoman[QUOTED] likes this.
