P0171 problems, Help?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Chrissteffen599, Oct 17, 2014.
  1. Oct 17, 2014 at 7:48 AM
    Chrissteffen599
    Chrissteffen599 [OP] Well-Known Member
    Texas
    02 tacoma
    Bilstein 5100 all around Allpro front and rear bumpers Trailgear turn signals Hella 700ff HID conversion
    So I got this code about 3-4 days ago and yesterday I bought some MAF cleaner and tackled that. However, I only sprayed one of the bulbs I could see without actually removing the entire MAF. It tripped again last night so do you think it needs to be completely taken out and cleaned with the MAF cleaner? It is still saying fuel system running too lean. Also, I had a pretty dirty air filter. Not sure if that would contribute or not! Thanks everyone!
  2. Oct 18, 2014 at 9:36 PM
    NOLA ItsNotOva
    NOLA ItsNotOva Well-Known Member
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    Its best for you to take the MAF sensor off to clean it. Make sure not to touch the little sensors inside. Clean it and let it air dry for about 30 minutes. Also change your air filter. If that doesn't help, then you may need a new one
  3. Oct 20, 2014 at 7:25 AM
    knuckleduster271
    knuckleduster271 Well-Known Member
    Baron Longrod Von Hug€nschlong
    ohio
    98 sr5 xtra cab
    881's, 5100's, soft 8's, elocker, matrix seats, smittybilt xrc8.
    I had the same code and it took me forever to finally figure it out.
    Turned out that i had alot of rust in my fuel tank and the strainer was clogged up causing it to stave for fuel.
  4. Oct 20, 2014 at 7:26 AM
    mustangstephen
    mustangstephen raise hell, drink beer
    Stephen
    by da creek
    02 Tacoma TRD
    Homebrew bumpers and sliders, 5100s & Eibachs up front and mutt leaf pack out back, 285s & Wheelers type B, sway bar deleted. Wife's ride: 01 4Runner 4wd sport. Stock with exception of TRD taco coils, and shift kit.
    Every time I have it the MAF sensor just needs to be cleaned. Take it out and spray it good.
  5. Oct 20, 2014 at 7:44 AM
    SpeedoJosh
    SpeedoJosh Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
    I chased this code for awhile too. Turned out to be fuel pressure issue. Changed the fuel pump, and it went away. Same thing happened to my 3rd gen 4runner. Only difference in the 4runner and the tacoma was the tacoma's fuel pump was weak for awhile, and never really noticed any issue until I tested the fuel pressure. 4runner fuel pump started acting up, and bit the bucket within a week.
    I doubt it's your MAF, especially if you just cleaned it, and it's still showing.
