P0171 Solved, FINALLY!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by SpeedoJosh, May 24, 2014.
  1. Sep 16, 2019 at 4:05 PM
    eon_blue
    Azusa, CA
    P0171 is most commonly caused by vacuum leaks...probably best to look for one before taking the time to replace the fuel pump (regarding the posts above about cleaning the MAF and then deciding to do the fuel pump).
    I fought this code for awhile too and it ended up being a small vacuum leak
  2. Sep 17, 2019 at 4:52 PM
    Stitz
    Stitz Well-Known Member
    South Jersey
    2024 TRD OR Supersonic
    bingo...had the same issue on my 99 taco. Did two easy things:
    1) clean MAF sensor (K&N filter causing contamination)
    2) replace a bunch of rotted, leaking vacuum hoses
    knock on wood, no more CEL popping up yet
    eon_blue[QUOTED] likes this.
  3. Sep 18, 2019 at 1:13 PM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    Aside from the code, how was it running? I suspect my fuel pump is not long for this world. If I have to go through the BS of trying to test it, I will just change it. Was it running crappy?
  4. Aug 20, 2020 at 7:13 PM
    mathesino
    mathesino New Member
    2011 Tacoma TRD Sport
    Old Man Emu Suspension Oilfield pumping truck
    I am having the same CEL issue but mine is only at an idle. My Oring/gasket around the MAF sensor is also very cracked. I will start here. Hope its this easy. LOL
    Thanks for the insight
  5. Aug 19, 2023 at 12:45 PM
    Levisbustedtacoma
    Levisbustedtacoma Well-Known Member
    Levi
    01 4x4 extracab
    Bilstien 5100s eibach coils Dakar leafs Chinese balljoints
    How do I check the fuel pressure at the rail and what should it be?
  6. Nov 23, 2024 at 5:32 AM
    rydr1
    rydr1 Well-Known Member
    Thanks for posting this information as well as the things you ran through. It helped me diagnose my 2006 Tacoma 4.0L with 125,000 miles.
    Same faults and verified that I had no external air leaks. Cleaned MAF and verified readings. Saw that I would get a value of 35 on my Long Tern Fuel trim bank 2 on the scan gauge when accelerating. Found fuel pressure below 41PSI.
    Replaced fuel pump from rock auto as well. Used the Denso repair kit for about $110 and installed a new fuel pump unit o-ring. I had a Toyota tech teach me to move the front of the tank downward and use the ring tool to remove the pump. If you use the repair kit, don't forget the small o-ring to the fuel filter unit.
  7. Apr 28, 2025 at 11:45 PM
    Rickfastly
    Rickfastly New Member
    02 Tacoma SR5 3.4L V6
    My truck had a P1135 code when I purchased it. Severe lack of power and running rich. I replaced PCV value, A/F ratio sensor(bank 1 Sensor 1), and cleaned my air intake system. Truck ran significantly better but then popped a P0171 code maybe 30 miles afterward. I simply pulled out my MAF sensor and cleaned the harness and sensor and boom, code went away and not issues since.
    Dalandser likes this.
  8. May 1, 2025 at 7:24 PM
    Tacotony1624
    Tacotony1624 Well-Known Member
    Central Valley/California
    1995 Tacoma 2.4L. 2WD/RWD
    Had the same for my 95 taco
    turned out it was a bad MAF and a small exhaust manifold leak smh. Replaced both and CEL went away and now I have under 10% fuel trim levels.
    That dam code can be a nightmare to diagnose lol I can see why some ppl just activate the parts cannon and fire all the repairs to their truck trying to fix it lol
