P0171 to P0420 check engine
Discussion in '1st Gen. Tacomas (1995-2004)' started by PrerunnerVsix, Jul 27, 2015.
  1. Jul 27, 2015 at 8:26 PM
    PrerunnerVsix
    PrerunnerVsix [OP] Well-Known Member
    Ali
    Houston, Tx
    2013 Tacoma TRD Sport
    About a week after I bought my tacoma the check engine light came on with a P0171 system lean in bank 1 code and I also noticed very poor mpg. The maf sensor was pretty dirty so I cleaned it with maf spray cleaner and reset the check light, mpg was instantly a lot better. Now a few days later check engine light came back on but with a P0420 catalyst system efficiency below threshold- bank 1 code. Also I believe mpg is low again. What should I do next? Thank you
  2. Jul 27, 2015 at 8:27 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Try a new gas cap.
  3. Jul 27, 2015 at 8:38 PM
    PrerunnerVsix
    Ali
    Houston, Tx
    Ok , I'll do that tomorrow morning. But shouldnt it be a different code if the gas cap was bad?
  4. Jul 27, 2015 at 8:41 PM
    PrerunnerVsix
    Ali
    Houston, Tx
  5. Jul 27, 2015 at 8:46 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Emissions leak would pretty much start at the gas cap I would think but I could be wrong.
  6. Jul 27, 2015 at 8:50 PM
    PrerunnerVsix
    Ali
    Houston, Tx
    P0420 is for air leak in exhaust before rear h02s , AF sensor error, fuel system fault , or faulty catalytic convertor. Not emissions leak I believe
  7. Jul 27, 2015 at 8:51 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Subbed for answer.
  8. Jul 27, 2015 at 11:22 PM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    Gas cap would trigger an EVAP related code. A EVAP leak could cause excess o2 to enter during purge cycles...but causing a lean code by itself, unlikely...possible but unlikely. I would not think that is causing the CEL.
    Get yer vacuum gauge out. Check to find a leak, im thinking post combustion as there is a lean code. Might be an EGR line or exhaust manifold that is leaking, that would cause both codes. A manifold leak would turn up on the vacuum gauge. Also you can use an unlit propane torch or carb cleaner over certain points to check for vacuum leaks.
    If you have a good scanner (something better then the Torque app, which has a pretty slow refresh rate), you can reset the ECU and then monitor the fuel trim, short and long term. See if it leans out significantly right off.
  9. Jul 29, 2015 at 12:58 AM
    MikeZ
    MikeZ Well-Known Member
    Subbed. I have the exact same problem. I am lucky to get 14 mpg with these codes.
  10. Jul 29, 2015 at 1:15 AM
    DCLBFTW
    DCLBFTW Well-Known Member
    Minnesota
    06 dclb
    OME 887's, Bilsten 5100 up front at 0, dakers and nitro-charges in the back, 9500lb winch, 42" led light bar on an oem rack,ridgid d2's up front and 4 duallys cut in the bumper, Back rack with highlift mounted and a uws tool box 2500 watt power inverter, Body Armor4x4 front and back bumper, leer 100xq cap, all pro skids and sliders
    Me too i have a 430 and 420 codes any guesses
  11. Aug 3, 2015 at 2:26 PM
    ags22
    ags22 New Member
    I have just P0171....change MAF? or does the voltage check and ohmmeter check on all data tell you enough good/bad?
  12. Aug 3, 2015 at 2:45 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    I used to get the p0420 randomly every few months, after a few O2 sensors my catalytic converter started to rattle, since I've replaced it I've been over a year with no codes. Good MAF clean and check your sensors
  13. Aug 21, 2015 at 1:00 PM
    PrerunnerVsix
    Ali
    Houston, Tx
    Rear o2 seemed to get rid of it, has been 300 miles and no light
