P0171 what to try..
Discussion in '1st Gen. Tacomas (1995-2004)' started by austinsdad99, Apr 24, 2019.
  1. May 11, 2019 at 3:53 PM
    #41
    Tacotuesday1988
    Tacotuesday1988 only1spicytaco
    philadelphia
    TACO
    285s m/it's flowmaster true dual super 40 dual outlet throttle body spacer k&n intake pioneer double din with navi kicker 3 ways in all doors a.r.e camp cap 15% tint film on windows 15% windshield strip.
    well that's good but if it happens again .. you know what options you have
  2. May 11, 2019 at 4:14 PM
    #42
    austinsdad99
    austinsdad99 [OP] Well-Known Member
    1999 prerunner 3.4
    Yea, we will see if it stays off. I’m kinda doubting it.
  3. May 11, 2019 at 6:08 PM
    #43
    JPinFL
    JPinFL Well-Known Member
    '01 Tacoma Xtra Cab 4x4
    Mine will do that. Then comes back. The other day it was off for the whole day. It returned the next morning.
  4. May 11, 2019 at 6:32 PM
    #44
    Tacotuesday1988
    philadelphia
    TACO
    I mean it's like 10 bucks for the pack of foulers , just time and some wrenching to fix it after that... might need a torch to burn it out too
  5. May 12, 2019 at 12:56 PM
    #45
    austinsdad99
    1999 prerunner 3.4
    So far it hasn’t come back.
  6. May 12, 2019 at 6:25 PM
    #46
    Tacotuesday1988
    philadelphia
    TACO
    well that's great then
  7. May 13, 2019 at 2:21 PM
    #47
    austinsdad99
    1999 prerunner 3.4
    Spoke too soon lol. It’s baaaaack.
  8. May 13, 2019 at 5:30 PM
    #48
    Tacotuesday1988
    philadelphia
    TACO
    lol u know what has to be done
    austinsdad99[OP] likes this.
  9. May 17, 2019 at 6:29 AM
    #49
    Barney387
    Barney387 Well-Known Member
    Corey
    2016 Mag Gray TRD-OR 6spd Manual
    Sema Pro Matte Gray Wheels, Toyo open country 265/70/17, backflip mx4, Opt7 35W HID.
    Finally fixed mine for good. Paid a local shop to diagnose it, this is what they found. Water temperature sensor was reading 50˚ lower than actual water temperature AND the Mass Airflow sensor was only reading 3.5 gm/s at idle when it should be somewhere around 7. Not sure about that measurement, just going off of what they told me. This caused the ECU to call for a lean mixture which in turn caused the code. I can't fully wrap my mind around that right now, but no code after 300 miles of driving makes me happy. Replaced the water temp sensor ($40) and MAF sensor ($77 Amazon *Denso)
    Now we get to move on to fixing the stuff that it actually needs, brakes, valve cover gaskets, timing belt.
  10. May 17, 2019 at 7:16 AM
    #50
    Glamisman
    Glamisman Well-Known Member
    sounds like you found a shop that truley knows what they are doing, that is good news.
    All of the sensors are part of a system, inputs are measured... air temp, air volume, water temp, rpm etc and from that fuel delivered via the injectors is controlled, spark adjusted, etc. A/F sensors, O2 sensors measure the result of the combustion process and compare it to know good values. If the values are out of range, adjustments are made, if the range of adjustments is beyond what can be adjusted, the CEL is illuminated.
