P0172 Bank 1 rich and hard starts after stalling in 4 low
Discussion in '1st Gen. Tacomas (1995-2004)' started by Wulf, Aug 14, 2019.
  1. Mar 10, 2020 at 8:22 AM
    #41
    Wulf
    Wulf [OP] auto dismantling & hoarding disorder
    rock raisin
    I swapped the injectors for a used set of the 95-97 metal body injectors. My long term fuel trims were in the -8.8 to -0.78 range driving around town yesterday
    GQ7227 likes this.
  2. Mar 10, 2020 at 8:26 AM
    #42
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Is that good or bad?
  3. Mar 10, 2020 at 8:26 AM
    #43
    cruiserguy
    Elijah
    SEKS
    Or is that what we're supposed to tell ya? :D:rofl:
    Oops lol
  4. Mar 10, 2020 at 8:37 AM
    #44
    Wulf
    rock raisin
    That is an improvement; I was seeing -18 LTFT before
    1997tacomav6 likes this.
  5. Mar 10, 2020 at 8:41 AM
    #45
    cruiserguy
    Elijah
    SEKS
    Oh okay sweet. Huge improvement. That much fuel being pulled from mix though, is that a vac leak? Or is that within the tolerance of the ECU learning and correcting it okay?
  6. Mar 10, 2020 at 8:51 AM
    #46
    1997tacomav6
    Denver
    Did you replace the injectors with the same earlier model injectors?
    The 1999-2004 are a bit more flow rate
  7. Mar 10, 2020 at 9:02 AM
    #47
    Wulf
    rock raisin
    I swapped to the early injectors. I had the brown body ones from an 02 in it previously -- I swapped the engine from an 02 into the truck in 2016
    It also seems to run a bit better now but that's so hard to judge :notsure:
    GQ7227 likes this.
  8. Mar 10, 2020 at 9:04 AM
    #48
    Wulf
    rock raisin
    AFAIK it's supposed to be +- 10 percent so I am in spec now when I was not before
    cruiserguy[QUOTED] likes this.
  9. Mar 10, 2020 at 9:30 AM
    #49
    eon_blue
    Azusa, CA
    yeah that's a lot better than what it was
