P0174 and P0171 then back to P0174 again!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacowestley, Apr 17, 2022.
  1. Apr 17, 2022 at 2:27 PM
    tacowestley
    tacowestley [OP] Khmer Member
    Wes
    562/626, CA
    05 DC Prerunner OR
    8k HIDs, flowmaster, bora wheel spacers 1.25'', debadged tailgate, DRL and foglight anytime mod, BHLM, 09+ LED tailights, painted valence black, mickey thompson classics 16'', switchback LEDs, reverse LEDs, tailgate clamp
    Hi everyone!
    Check engine light turned on, scanned it and said I had a P0174 code meaning engine running lean on bank 2 (driver side). I changed out the air/fuel sensor on that side and cleared the light. I drove about 60 miles and the light came back on. I got home and scanned it again and it now read that the passenger side was now running lean (bank 1) with the code P0171. Went to O'rielly and the guy said that since the driver side was new, it was tripping the other side which meant I would need to change the passenger side as well. I changed it, cleared the light, drove around, engine light came back on AGAIN. I scanned the truck once again, and now it was only showing the P0174 code again even though at this point both sides are new now...Thoughts? Should I keep driving the truck around for the computer to catch up or could it be another issue lingering?
    Sorry for the long-ish post but I couldnt really condense what I had to say lol
  2. Apr 17, 2022 at 2:33 PM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    Most likely the O'Reillys guy is full of bull as well as the sensors not being the issue. The light will stay out for a while because the monitor doesn't run right away but once it does it sets the code
  3. Apr 17, 2022 at 2:45 PM
    tacowestley
    Wes
    562/626, CA
    05 DC Prerunner OR
    When I took out the old sensors, they were pretty burned so it was time to replace them anyway. Should I just wait until the computer turns off the light and keep driving? I just changed the driver side last week, and the passenger side a few days ago
  4. Apr 17, 2022 at 2:54 PM
    AJKlug1
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Were the old sensors really black?
  5. Apr 17, 2022 at 2:59 PM
    tacowestley
    Wes
    562/626, CA
    05 DC Prerunner OR
    not really, but they were brown on the verge of turning black? they just looked old honestly.
    Ill try to upload a couple pics
  6. Apr 17, 2022 at 3:00 PM
    AJKlug1
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Ok, You can keep driving it in the short term but I would have that looked into... Good luck!
  7. Apr 17, 2022 at 3:30 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Really need to look at fuel trims idling and driving to try to determine what's going on, 90% of the time it's not the O2/AFR sensors that cause lean codes.
    Vacuum leaks, low fuel pressure, and dirty or skewed Mass Airflow sensor are ususally the primary suspect areas to check first.
    b_r_o, tacowestley[OP] and TnShooter like this.
  8. Apr 17, 2022 at 3:43 PM
    tacoma909sport
    tacoma909sport Well-Known Member
    So Cal
    14 DoubleCab Sport
    i’m not sure if it’s the same universal code, but i think i had a similar code on my turbo subaru. i think it was a boost leak, means the intake manifold had a leak, and fuel/air that was entering the engine, wasn’t being accounted for by the MAF sensor, thus i had bad performance and that 0174 code.
    look for a intake manifold leak.
    tacowestley[OP] likes this.
  9. Apr 17, 2022 at 5:36 PM
    tacowestley
    Wes
    562/626, CA
    05 DC Prerunner OR
    hoses are good, MAF (gasket and sensor itself) is good, idk about the fuel pressure, maybe I should check that out then.
    thanks for the reply !
  10. Apr 17, 2022 at 5:38 PM
    tacowestley
    Wes
    562/626, CA
    05 DC Prerunner OR
    thank you for the reply. I wouldnt be surprised as toyota and subaru have partnerships. Am I suppose to hear something when it comes to intake manifold leak?
  11. Apr 17, 2022 at 10:15 PM
    tacoma909sport
    So Cal
    14 DoubleCab Sport
    not sure how to easily find a vacuum leak, usually you can find it by spraying the area that is leaking with carb cleaner or brake cleaner, the engine will make a noticeable change in rpm at idle, and possibly sound like it will stall.
    some hard to find leaks can be found with a smoke generator. youtube is your best friend. i hope im not leading you down the wrong hole. good luck.
  12. Apr 18, 2022 at 1:27 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    I got over 360k on my original O2 and AFR sensors. I had a P0420 code once and swapped the O2 sensors. But other than that, they've never been touched.
    A bad gasket was the cause of my code. I found a tiny soot mark. That was all it took.
    Scope things out carefully before loading the parts cannon
  13. Apr 18, 2022 at 2:09 PM
    tacoma909sport
    So Cal
    14 DoubleCab Sport
    where was this gasket you speak of?
  14. Apr 18, 2022 at 2:18 PM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    What do you mean they were "burned?" The actual sensor is inside the shield and is very hard to see. Are you talking about the part that is in the exhaust stream, and it having some carbon on it? That's normal.
